11-20-2016, 07:11 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 822148 Status: Offline Thanks Meter: 1 | LGH860 unlock FRP Problem Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: H860 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H860 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 86% SW Version: H86010a Mode: Emergency Initializing flash...OK SW version: LGH860AT-00-V10i-TWN-XX-OCT-18-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: HD54S160518000807 IMEI: 358394-07-361893-1 Target operator: GLOBAL Hardware: rev_11 Reading partitions...OK Resetting FRP Lock...Failed! Performed by 2.5.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: H860 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H860 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 86% SW Version: H86010a Mode: Emergency Initializing flash...OK SW version: LGH860AT-00-V10i-TWN-XX-OCT-18-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: HD54S160518000807 IMEI: 358394-07-361893-1 Target operator: GLOBAL Hardware: rev_11 Reading partitions...OK Resetting FRP Lock...Failed! Performed by 2.5.0 Software version. How to fix this problem?? Br Obeone |
11-21-2016, 08:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Reset FRP operation is currently not supported for the latest firmware, which is in your device (LGH860AT-00-V10i-TWN-XX-OCT-18-2016+0). We work on new Reset FRP method. As soon as solution will be ready, we will release it. Last edited by Octopus box; 11-21-2016 at 09:31. |
11-22-2016, 12:39 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, download and install test Software version form the Support Area (LG/TEST SOFTWARE/) then repeat operation which You need again, post here full Software log. |
