03-09-2014, 01:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: mexico
Member: 461616 Status: Offline Thanks Meter: 32 | LGMS769 no service after unlock [Solved] Last edited by Octopus box; 10-16-2014 at 14:03. |
03-09-2014, 06:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to make "Repair EEPROM", try to use other SIM cards, try to search and select network manually. |
03-11-2014, 02:03 | #3 (permalink) |
Member: 461616 Status: Offline Thanks Meter: 32 | Done, i restore the original EEPROM was made by the software but, the phone no longer gave me signal, i was request the code by server and the phone was unlocked, then i test it and just is in ''searching'' or ''no service'' IMEI is fine. I don't understand why doesn't work, the variants like P769 and P768g works perfectly but this.... i hope you team work about this MS769. any other suggest to check it out in this phone? the phone is no longer in my hans but i can try again when the solution is safe |
03-11-2014, 07:18 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
06-27-2014, 22:34 | #5 (permalink) |
Junior Member Join Date: May 2014
Member: 2194942 Status: Offline Thanks Meter: 0 | Same problem here. Phone doesnt pick up signal after IMEI repair. Mobile network is greyed out and cannot be selected. If i power the phone on without any sim card it picks up signal bars, i tried 10 sim cards and all of them stays on Searching.... |
06-28-2014, 07:48 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ maakaroun 1. Post here full Software log with that Repair IMEI operation. 2. Install the latest Software version (Software). 3. Make Repair EEPROM. 4. Make Unlock. 5. Perform the Repair IMEI operation. 6. Insert SIM card, re-start the phone, wait 3-5 minutes and try to search and select network manually. 7. Post here full Software log with all of these actions and say the result. Also, try to re-flash the phone with the firmwares from the Support Area. |
07-21-2014, 19:44 | #7 (permalink) | |
Member: 461616 Status: Offline Thanks Meter: 32 | Quote:
10-16-2014, 13:50 | #9 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1207202 Status: Offline Thanks Meter: 44 | Welcome to Octoplus/Octopus Box LG Software version 1.7.0 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: MS769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...Canceled! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: MS769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...OK IMEI: 013647-00-509914-1 Bluetooth address: BC:F5:AC:34:38:A4 Wi-Fi MAC address: BC:F5:ACE:16F Locks: Service Provider Lock MCC=310 (USA) MNC=160 Unlocking... Reading EEPROM...OK Backup saved to "MS769_013647005099141_16-10-2014_14-47-52.EEP" Writing EEPROM...OK Phone successfully unlocked! i have all lg box,octopus is best one |
The Following User Says Thank You to Xpress_banha For This Useful Post: |
