04-21-2020, 07:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | LM-X120EMW unlock failed [Answered] 3.0.1 ------------------------------------------------------------------------ -------- Checking data...OK Platform: LG MTK Selected port: COM155 Selected baudrate: 921600 Selected model: X120EMW Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM32 Mode: Emergency Initializing flash...OK Model ID: LM-X120EMW Platform: mt6739 Android version: 9 SW version: LMX120EMWAT-64-V10j-EEA-XX-SEP-12- 2019+0 LAF Version: 1.1 Product ID: WI18S191111003690 IMEI: 356276-10-794417-1 Target operator: LAO Hardware: rev_10 Battery level: 16% Reading partitions...OK LAF Error: 80000119. Checking security...OK ------------------------------------------------------------------------ -------- IMEI A: 356276-10-794417-1 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown ------------------------------------------------------------------------ -------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Performed by 3.0.1 Software version. ------------------------------------------------------------------------ -------- Connecting to server ...OK Username: naseer Authorizing...OK Checking balance...OK Your balance: 100 credits. ------------------------------------------------------------------------ -------- Checking data...OK Platform: LG MTK Selected port: COM155 Selected baudrate: 921600 Selected model: X120EMW Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM32 Mode: Emergency Initializing flash...OK Model ID: LM-X120EMW Platform: mt6739 Android version: 9 SW version: LMX120EMWAT-64-V10j-EEA-XX-SEP-12- 2019+0 LAF Version: 1.1 Product ID: WI18S191111003690 IMEI: 356276-10-794417-1 Target operator: LAO Hardware: rev_10 Battery level: 16% Reading partitions...OK LAF Error: 80000119. Checking security...OK ------------------------------------------------------------------------ -------- IMEI A: 356276-10-794417-1 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown ------------------------------------------------------------------------ -------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: naseer Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area...OK Removing write protection...OK Reconnecting phone... Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. Phone found at port COM32 Mode: Emergency Initializing flash...OK Erasing part 1...OK Reconnecting phone... Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. Phone found at port COM32 Mode: Emergency Initializing flash...OK Erasing part 2...OK Phone successfully unlocked! Please, reboot the phone manually. Performed by 3.0.1 Software version. struck on logo after unlock |
04-21-2020, 08:00 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, download and install the latest test Software version from the Support Area and repeat operation again, we've added You one more attempt, next time use forum search button first! |
