11-13-2018, 23:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | LM-X210CM multiple unlocks done sucessfully!! -------------------------------------------------------------------------------- Connecting to server ...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Your balance: 400 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: LMX210CM Reading info... Could not detect mode! Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM490 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-397431-5 Android version: 7.1.2 Battery level: 50% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-397431-5 Bluetooth address: 00:57:C1:14:42:6D Wi-Fi MAC address: 00:57:C1:BC:7C:0D SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 400 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376093974315_13-11-2018_15-16- 22.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM* ÿh at port COM490 Sending data to server...OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM493 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-399680-5 Android version: 7.1.2 Battery level: 48% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-399680-5 Bluetooth address: 00:57:C1:14:6A:0A Wi-Fi MAC address: 00:57:C1:BC:A3:B2 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 350 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376093996805_13-11-2018_15-28- 01.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM* ÿh at port COM493 Sending data to server...OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM495 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-429227-9 Android version: 7.1.2 Battery level: 50% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-429227-9 Bluetooth address: 00:57:C1:1A:AC3 Wi-Fi MAC address: 00:57:C1:C2:E7:64 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 300 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376094292279_13-11-2018_15-41- 20.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM* ÿh at port COM495 Sending data to server...OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: LMX210CM Reading info... Could not detect mode! Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM498 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-397181-6 Android version: 7.1.2 Battery level: 51% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-397181-6 Bluetooth address: 00:57:C1:14:3D:AB Wi-Fi MAC address: 00:57:C1:BC:77:46 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 250 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376093971816_13-11-2018_15-54- 28.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM* ÿh at port COM498 Sending data to server...OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: LMX210CM Reading info... Could not detect mode! Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM502 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-414249-0 Android version: 7.1.2 Battery level: 47% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-414249-0 Bluetooth address: 00:57:C1:19:AD:40 Wi-Fi MAC address: 00:57:C1:C1:E7:43 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376094142490_13-11-2018_16-04- 44.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM* ÿh at port COM502 Sending data to server...OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM505 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-399482-6 Android version: 7.1.2 Battery level: 22% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-399482-6 Bluetooth address: 00:57:C1:14:66:7E Wi-Fi MAC address: 00:57:C1:BC:A0:22 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 150 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376093994826_13-11-2018_16-14- 15.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM* ÿh at port COM505 Sending data to server...OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM508 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-397445-5 Android version: 7.1.2 Battery level: 50% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-397445-5 Bluetooth address: 00:57:C1:14:42:9F Wi-Fi MAC address: 00:57:C1:BC:7C:3F SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Gambitv01 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 50 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376093974455_13-11-2018_16-32- 44.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM* ÿh at port COM508 Sending data to server...OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9.7 Software version. |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
