12-14-2018, 08:18 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: gujrat rajkot india
Member: 451802 Status: Offline Thanks Meter: 35 | LM-X210IMW Reset FRP problem [Answered] HERE IS LOG PLEASE GIVE ANY SOLUTION Reading info... Model ID: LM-X210IMWX210IMW10c IMEI: 353461-09-00XXXX-1 Android version: 7.1.2 Battery level: 24% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210IMWAT-00-V10d-IND-XX-AUG-30-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: EV01S180808000205 IMEI: 353461-09-00XXXX-1 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210IMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock...Failed! Performed by 2.9.1 Software version. Last edited by Octopus box; 12-14-2018 at 12:52. |
12-14-2018, 12:51 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Unfortunately, at the moment "Reset FRP" operation is not supported for your device firmware: Quote:
01-24-2019, 11:07 | #3 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heart
Member: 2144988 Status: Offline Sonork: 100.1655364(Offline) Thanks Meter: 217 | Now Done Welcome to Octoplus/Octopus Box LG Software version 2.9.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM33 Selected model: LMX210IMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210IMWX21010t IMEI: 3XXXXX-0X-XXXXXX-0 Android version: Battery level: 31% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210IMWAT-00-V10d-IND-XX-AUG-30-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 3XXXXX-0X-XXXXX-0 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210IMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...OK Resetting FRP Lock...OK Formating encrypt...OK Rebooting phone... Resetting FRP lock successfully completed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.9.2 Software version. Last edited by Hifzul Amin; 01-24-2019 at 11:08. Reason: Hide Imei |
The Following User Says Thank You to Hifzul Amin For This Useful Post: |
04-24-2019, 18:18 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: everyones heart Age: 44
Member: 488940 Status: Offline Sonork: 100.1594730 Thanks Meter: 110 | Welcome to Octoplus/Octopus Box LG Software version 2.9.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM31 Selected model: LMX210IMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210IMWX210IMW10e IMEI: 3534----------- Android version: 7.1.2 Battery level: 40% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210IMWAT-00-V10e-IND-XX-MAR-12-2019+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: EV01S181221000457 IMEI: 353461-09-292779-4 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210IMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock...Failed! Performed by 2.9.4 Software version. any solution please. |
05-09-2019, 12:05 | #6 (permalink) |
Junior Member Join Date: Oct 2008 Location: chennai
Member: 879731 Status: Offline Sonork: 1234 Thanks Meter: 5 | Platform: LG Qualcomm Selected port: COM37 Selected model: LMX210IMW Reading info... Model ID: LM-X210IMWX210IMW10d IMEI: 353461-09-130445-8 Android version: 7.1.2 Battery level: 42% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210IMWAT-00-V10d-IND-XX-AUG-30-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: EV01S181014002372 IMEI: 353461-09-130445-8 Target operator: LAO Hardware: rev_10 Performed by 2.9.4 Software version. |
05-09-2019, 12:06 | #7 (permalink) |
Member: 879731 Status: Offline Sonork: 1234 Thanks Meter: 5 | Checking data...OK Platform: LG Qualcomm Selected port: COM37 Selected model: LMX210IMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210IMWX210IMW10d IMEI: 353461-09-130445-8 Android version: 7.1.2 Battery level: 42% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210IMWAT-00-V10d-IND-XX-AUG-30-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: EV01S181014002372 IMEI: 353461-09-130445-8 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210IMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock...Failed! Performed by 2.9.4 Software version. |
05-09-2019, 12:35 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortuantely, Reset FRP isn't supported on your version of security patch, if You can find lover firmwre version, You may try to downgrade and repeat Reset FRP operation once again |
