07-10-2020, 06:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | LMX210IMW frp error [Answered] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM122 Selected model: LMX210IMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 2.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM122 Selected model: LMX210IMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210IMWX210IMW10c IMEI: 353461-09-063973-0 Android version: 7.1.2 Battery level: 68% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210IMWAT-00-V10d-IND-XX-AUG-30-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 353461-09-063973-0 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210IMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.9.8 Software version. |
07-10-2020, 07:50 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. Please download and install latest test software version 3.0.2.03 from the Support Area (LG/TEST SOFTWARE/), then try to do Reset FRP operation once again. Quote:
07-10-2020, 09:14 | #3 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
Card S/N : 0200039271 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM22 Selected model: LMX210IMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 3.0.2.03 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM122 Selected model: LMX210IMW Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X210IMWX210IMW10c IMEI: 353461-09-063973-0 Android version: 7.1.2 Battery level: 68% Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LMX210IMWAT-00-V10d-IND-XX-AUG-30-2018+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: IMEI: 353461-09-063973-0 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX210IMW will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Reading partitions... Performed by 3.0.2.03 Software version. | |
07-10-2020, 09:43 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, try to download and install latest test Sofwtare version from the Support Area, after repeat operation again, we've add some changes to Software |
07-10-2020, 11:59 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | The latest test Software version is 3.0.2.4, You can download it from the Support Area, check for Test Software folder! |
11-18-2020, 08:34 | #7 (permalink) | |
Insane Poster Join Date: Apr 2014 Location: India
Member: 2170791 Status: Offline Thanks Meter: 50 | Quote:
