01-17-2020, 00:14 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | LMX520HM done but imei 0 [Solved] Welcome to Octoplus/Octopus Box LG Software version 2.9.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM22 Selected baudrate: 921600 Selected model: X520HM Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM21 Mode: Emergency Initializing flash...OK Model ID: LM-X520HM Platform: mt6765 Android version: 9 SW version: LMX520HMAT-00-V10d-SCA-XXX-NOV-21-2019+0 LAF Version: 1.1 Product ID: 975GAN68BNT801V6V IMEI: 355472-10-108985-4 Target operator: LAO Hardware: rev_10 Battery level: 97% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 355472-10-108985-4 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: richiricherd5x Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Fixing IMEI... Patching security... Writing security area...OK Removing write protection...OK Reconnecting phone... Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. Phone found at port COM21 Mode: Emergency Initializing flash...OK Erasing part 1...OK Reconnecting phone... Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. Phone found at port COM21 Mode: Emergency Initializing flash...OK Restore write protection...OK Erasing part 2...OK IMEI successfully fixed! Please, reboot the phone manually. Performed by 2.9.8 Software version. |
01-17-2020, 08:57 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please download and install latest test software version 2.9.8.1 from the Support Area (LG/TEST SOFTWARE/), then repeat the operation once again. We added You one more attempt. Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
01-20-2020, 10:19 | #4 (permalink) |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | refund 100 credits imei 00000000000000000000 Welcome to Octoplus/Octopus Box LG Software version 2.9.8.11 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM149 Selected baudrate: 921600 Selected model: X520HM Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM148 Mode: Emergency Initializing flash...OK Model ID: LM-X520HM Platform: mt6765 Android version: 9 SW version: LMX520HMAT-00-V10a-334-020-SEP-06-2019+2 LAF Version: 1.1 Product ID: 96GGAN68BC8B0132L IMEI: 000000-00-000000-0 Target operator: LAO Hardware: rev_10 Battery level: 35% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 000000-00-000000-0 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: chivatazo13_02 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Too low balance to provide the security operation! Your balance: 0 credits. To perform "Repair IMEI" operation you need to have 100 credits. Performed by 2.9.8.11 Software version. |
01-20-2020, 10:43 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | First of all please post here full Software log with all performed operations for this device! Becasue, as i can see this is second attempt |
01-20-2020, 10:51 | #6 (permalink) | |
Member: 1958094 Status: Offline Thanks Meter: 57 | Quote:
18/01/2020 06:23:09 p.m. > Platform: LG MTK 18/01/2020 06:23:09 p.m. > Selected port: COM198 18/01/2020 06:23:09 p.m. > Selected baudrate: 921600 18/01/2020 06:23:09 p.m. > Selected model: X520HM 18/01/2020 06:23:09 p.m. > Selected USB connection type 18/01/2020 06:23:10 p.m. > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 18/01/2020 06:23:10 p.m. > or 18/01/2020 06:23:10 p.m. > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable.18/01/2020 06:24:51 p.m. > Failed! 18/01/2020 06:24:51 p.m. > Could not detect mode. 18/01/2020 06:24:51 p.m. > Performed by 2.9.8 Software version. 18/01/2020 06:24:51 p.m. > Elapsed Time: 12:01:42 a.m. 18/01/2020 06:43:32 p.m. > Checking data...18/01/2020 06:43:33 p.m. > OK 18/01/2020 06:43:33 p.m. > Platform: LG MTK 18/01/2020 06:43:33 p.m. > Selected port: COM198 18/01/2020 06:43:33 p.m. > Selected baudrate: 921600 18/01/2020 06:43:33 p.m. > Selected model: X520HM 18/01/2020 06:43:33 p.m. > Selected USB connection type 18/01/2020 06:43:34 p.m. > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 18/01/2020 06:43:34 p.m. > or 18/01/2020 06:43:34 p.m. > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 18/01/2020 06:43:39 p.m. > Phone found at port COM5 18/01/2020 06:43:39 p.m. > Mode: Emergency 18/01/2020 06:43:39 p.m. > Initializing flash...18/01/2020 06:43:41 p.m. > OK 18/01/2020 06:43:42 p.m. > Model ID: LM-X520HM 18/01/2020 06:43:42 p.m. > Platform: mt6765 18/01/2020 06:43:42 p.m. > Android version: 9 18/01/2020 06:43:42 p.m. > SW version: LMX520HMAT-00-V10a-334-020-SEP-06-2019+2 18/01/2020 06:43:42 p.m. > LAF Version: 1.1 18/01/2020 06:43:42 p.m. > Product ID: 96GGAN68BC8B0132L 18/01/2020 06:43:42 p.m. > IMEI: 355472-10-058932-6 18/01/2020 06:43:42 p.m. > Target operator: LAO 18/01/2020 06:43:42 p.m. > Hardware: rev_10 18/01/2020 06:43:42 p.m. > Battery level: 18% 18/01/2020 06:43:42 p.m. > Reading partitions...18/01/2020 06:43:42 p.m. > OK 18/01/2020 06:43:43 p.m. > LAF Error: 80000119. 18/01/2020 06:43:45 p.m. > Checking security...18/01/2020 06:43:45 p.m. > OK 18/01/2020 06:43:45 p.m. > Reading is Blocked! 18/01/2020 06:43:45 p.m. > -------------------------------------------------------------------------------- 18/01/2020 06:43:45 p.m. > IMEI: 355472-10-058932-6 18/01/2020 06:43:45 p.m. > Bluetooth address: Unknown 18/01/2020 06:43:45 p.m. > Wi-Fi MAC address: Unknown 18/01/2020 06:43:45 p.m. > -------------------------------------------------------------------------------- 18/01/2020 06:43:45 p.m. > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 18/01/2020 06:43:48 p.m. > Connecting to server...18/01/2020 06:43:52 p.m. > OK 18/01/2020 06:43:52 p.m. > Octopus smart card is present. 18/01/2020 06:43:52 p.m. > Checking smart card...18/01/2020 06:43:57 p.m. > OK 18/01/2020 06:43:57 p.m. > Username: chivatazo13_02 18/01/2020 06:43:57 p.m. > Authorizing...18/01/2020 06:43:58 p.m. > OK 18/01/2020 06:43:58 p.m. > Checking balance...18/01/2020 06:43:59 p.m. > OK 18/01/2020 06:43:59 p.m. > Checking operation...18/01/2020 06:44:01 p.m. > OK 18/01/2020 06:44:01 p.m. > Sending device information...18/01/2020 06:44:02 p.m. > OK 18/01/2020 06:44:02 p.m. > Get credits, needed for current operation...18/01/2020 06:44:04 p.m. > OK 18/01/2020 06:44:04 p.m. > Your balance: 100 credits. 18/01/2020 06:44:04 p.m. > To perform "Repair IMEI" operation you need to have 100 credits. 18/01/2020 06:45:31 p.m. > Fixing IMEI... 18/01/2020 06:45:31 p.m. > Patching security... 18/01/2020 06:45:31 p.m. > Writing security area...18/01/2020 06:45:34 p.m. > OK 18/01/2020 06:45:35 p.m. > Removing write protection... 18/01/2020 06:45:39 p.m. > Execute : 0x00F5 18/01/2020 06:45:39 p.m. > Writing cmd... 18/01/2020 06:45:39 p.m. > reading cmd... 18/01/2020 06:45:42 p.m. > reading cmd... 18/01/2020 06:45:44 p.m. > reading cmd... 18/01/2020 06:45:46 p.m. > reading cmd...18/01/2020 06:45:48 p.m. > OK 18/01/2020 06:45:48 p.m. > Reconnecting phone... 18/01/2020 06:45:48 p.m. > Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. 18/01/2020 06:48:38 p.m. > Phone found at port COM5 18/01/2020 06:48:38 p.m. > Mode: Emergency 18/01/2020 06:48:38 p.m. > Initializing flash...18/01/2020 06:48:40 p.m. > OK 18/01/2020 06:48:40 p.m. > Erasing part 1... 18/01/2020 06:48:43 p.m. > Execute : 0x00C3 18/01/2020 06:48:43 p.m. > Writing cmd... 18/01/2020 06:48:43 p.m. > reading cmd... 18/01/2020 06:48:45 p.m. > Read: EXEC...18/01/2020 06:48:45 p.m. > OK 18/01/2020 06:48:45 p.m. > Reconnecting phone... 18/01/2020 06:48:45 p.m. > Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. 18/01/2020 06:49:12 p.m. > Phone found at port COM5 18/01/2020 06:49:12 p.m. > Mode: Emergency 18/01/2020 06:49:12 p.m. > Initializing flash...18/01/2020 06:49:14 p.m. > OK 18/01/2020 06:49:15 p.m. > Restore write protection...18/01/2020 06:49:17 p.m. > OK 18/01/2020 06:49:17 p.m. > Erasing part 2... 18/01/2020 06:49:19 p.m. > Execute : 0x00F9 18/01/2020 06:49:19 p.m. > Writing cmd... 18/01/2020 06:49:20 p.m. > reading cmd... 18/01/2020 06:49:22 p.m. > reading cmd... 18/01/2020 06:49:24 p.m. > reading cmd... 18/01/2020 06:49:26 p.m. > reading cmd...18/01/2020 06:49:28 p.m. > OK 18/01/2020 06:49:28 p.m. > IMEI successfully fixed! 18/01/2020 06:49:28 p.m. > Please, reboot the phone manually. 18/01/2020 06:49:28 p.m. > Performed by 2.9.8 Software version. 18/01/2020 06:49:28 p.m. > Elapsed Time: 12:05:55 a.m. Last edited by zapata13; 01-20-2020 at 10:58. | |
01-20-2020, 11:28 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You need to be more attentive: Octoplus LG Tool Update 2.9.8.1 Attention We've added You one more attempt, plesae repeat operation again |
