09-01-2018, 22:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | LS676 Reset FRP successfully done -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM280 Selected model: LS676 Reading info... IMEI: 354209-09-074676-8 Android version: 6.0.1 Battery level: 46% SW Version: LS676ZV9 Mode: Emergency Initializing flash...OK SW version: LS676ZV9_02 Android version: 6.0.1 LAF Version: 1.1 Product ID: CD28S171125001066 IMEI: 354209-09-074676-8 Target operator: SPR Hardware: rev_11 Unlock operation is currently not supported for your phone's firmware. Canceled! Performed by 2.8.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM280 Selected model: LS676 Reading info... IMEI: 354209-09-074676-8 Android version: 6.0.1 Battery level: 46% SW Version: LS676ZV9 Mode: Emergency Initializing flash...OK SW version: LS676ZV9_02 Android version: 6.0.1 LAF Version: 1.1 Product ID: CD28S171125001066 IMEI: 354209-09-074676-8 Target operator: SPR Hardware: rev_11 Opening "LS676ZV6_02.tot"...OK Firmware version: LS676ZV6 Firmware model: LS676 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/3 PrimaryGPT...OK Writing 2/3 modem...OK Writing 3/3 carrier...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM280 Selected model: LS676 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 354209-09-074676-8 Android version: 6.0.1 Battery level: 45% SW Version: LS676ZV9 Mode: Emergency Initializing flash...OK SW version: LS676ZV9_02 Android version: 6.0.1 LAF Version: 1.1 Product ID: CD28S171125001066 IMEI: 354209-09-074676-8 Target operator: SPR Hardware: rev_11 Reading partitions...OK Resetting FRP Lock...Failed! Reading partitions...OK Resetting FRP Lock... Step 1...OK Step 2...OK Step 3...OK Resetting FRP lock successfully completed! Performed by 2.8.8 Software version. Last edited by Octopus box; 09-02-2018 at 08:29. |
The Following User Says Thank You to chipscell25 For This Useful Post: |
