05-03-2017, 01:01 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: N/A
Member: 109335 Status: Offline Thanks Meter: 27 | LS676 unlock fixed This post's answer is intended to guide and help Finally FIXED unlock done. but: only using octopus box Unlock once again and then: initial service disabled message at startup but then after hidden menu service, ....boom unlocked and full signal but no data and no apn change option, until now Please, perform Open Hidden menu operation from the Android Tools tab in the Software, after check phone's screen You will see Hidden Menu, then try to do next: 1. Go to IOT(CDG2) option > LTE Settings > Operation mode. 2. select Lab Network option. Welcome to Octoplus/Octopus Box LG Software version 2.6.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM69 Selected model: LS676 Reading info... IMEI: 35878 Android version: 6.0.1 Battery level: 76% SW Version: LS676ZV4 Mode: Emergency Initializing flash...OK SW version: LS676ZV4_05 Android version: 6.0.1 LAF Version: 1.1 Product ID: CH32 IMEI: 35878 Target operator: SPR Hardware: rev_11 Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.6.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM69 Selected model: LS676 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LGLS676 Phone firmware version: LGLS676AT-00-ZV4-SPR-US-MAR-19-2017+05 Kernel version: 3.10.49-geb2878e (lgmobile@LGEACI9R2) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Sun Mar 19 09:49:55 KST 201 Android version: 6.0.1 Hardware: Qualcomm Technologies, Inc MSM8909 0 Sending exploit...OK Executing exploit...OK Opening Hidden Menu...OK Performed by 2.6.3 Software version. Last edited by Octopus box; 05-03-2017 at 06:18. |
The Following 2 Users Say Thank You to atv For This Useful Post: |
08-02-2017, 13:51 | #4 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Dominica Age: 59
Member: 39797 Status: Offline Thanks Meter: 13 | This solution appears to have been blocked. [QUOTE=atv;12479020]http://forum.gsmhosting.com/vbb/f453.../#post12479019 This post's answer is intended to guide and help Finally FIXED unlock done. but: only using octopus box Unlock once again and then: initial service disabled message at startup but then after hidden menu service, ....boom unlocked and full signal but no data and no apn change option, until now Please, perform Open Hidden menu operation from the Android Tools tab in the Software, after check phone's screen You will see Hidden Menu, then try to do next: 1. Go to IOT(CDG2) option > LTE Settings > Operation mode. 2. select Lab Network option. ------------------------------------------------------- It seems like LG may have blocked this solution. I did this procedure a few times over the last few months on customers' phones after update. Now a recent update seem to have blocked this solution. The IOT(DDG2) menu option is no longer available in the hidden menu. |
