11-28-2017, 17:15 | #9 (permalink) | |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Quote: same with this firmware Welcome to Octoplus/Octopus Box LG Software version 2.7.7.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: LS676 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.7.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: LS676 Reading info... IMEI: 357269-08-924859-5 Android version: 6.0.1 Battery level: 100% SW Version: LS676ZV7 Mode: Emergency Initializing flash...OK SW version: LS676ZV7_09 Android version: 6.0.1 LAF Version: 1.1 Product ID: CH33S170528000114 IMEI: 357269-08-924859-5 Target operator: SPR Hardware: rev_11 Opening "LS676ZV6_02.tot"...OK Firmware version: LS676ZV6 Firmware model: LGLS676 File declared for different phone model! Performed by 2.7.7.4 Software version. | |
12-05-2017, 10:23 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | We have prepared new test Software version, download and install it form the Support Area ("LG/TEST SOFTWARE/" folder), then repeat the "Unlock" operation again. Last edited by Octopus box; 12-05-2017 at 11:10. |
12-05-2017, 14:14 | #11 (permalink) |
Freak Poster Join Date: Dec 2014 Location: Surxondaryo denov
Member: 2318698 Status: Offline Thanks Meter: 15 | Thank you octopusbox unlock complete Checking data...OK Platform: LG Qualcomm Selected port: COM88 Selected model: LS676 Reading info... IMEI: 358784-07-390246-9 Android version: 6.0.1 Battery level: 93% SW Version: LS676ZV7 Mode: Emergency Initializing flash...OK SW version: LS676ZV7_09 Android version: 6.0.1 LAF Version: 1.1 Product ID: IMEI: 358784-07-390246-9 Target operator: SPR Hardware: rev_11 Opening "LS676ZV6_02.tot"...OK Firmware version: LS676ZV6 Firmware model: LS676 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/3 PrimaryGPT...OK Writing 2/3 modem...OK Writing 3/3 carrier...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.7.4 Software version. |
The Following 2 Users Say Thank You to gayrat_gsm For This Useful Post: |
12-06-2017, 12:44 | #12 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Checking data...OK Platform: LG Qualcomm Selected port: COM149 Selected model: LS676 Reading info... IMEI: 358784-07-XXXXXX-X Android version: 6.0.1 Battery level: 66% SW Version: LS676ZV7 Mode: Normal Firmware compiled date: Aug 09 2017 Firmware compiled time: 03:00:00 Firmware released date: Sep 19 2017 Firmware released time: 10:36:57 SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM- 1.59782.2.109829.1 IMEI: 358784-07-XXXXXX-X SPC: 645088 MEID: 358784072XXXXX Mobile ESN: 80396DD3 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 740395 NAM Name: Sprint User Lock Code: 7315 Unlock operation is currently not supported for your phone's firmware. Performed by 2.7.7.5 Software version. |
12-06-2017, 13:19 | #13 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Octopus Box LG Software version 2.7.7 Working Fine Code: Welcome to Octoplus/Octopus Box LG Software version 2.7.7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM149 Selected model: LS676 Reading info... IMEI: 358784-07-XXXXXX-X Android version: 6.0.1 Battery level: 55% SW Version: LS676ZV7 Mode: Normal Firmware compiled date: Aug 09 2017 Firmware compiled time: 03:00:00 Firmware released date: Sep 19 2017 Firmware released time: 10:36:57 SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM- 1.59782.2.109829.1 IMEI: 358784-07-257508-4 SPC: 645088 MEID: 358784072XXXXX Mobile ESN: 80396DD3 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 740395 NAM Name: Sprint User Lock Code: 7315 Performed by 2.7.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM149 Selected model: LS676 Reading info... IMEI: 358784-07-XXXXXX-X Android version: 6.0.1 Battery level: 55% SW Version: LS676ZV7 Mode: Normal Firmware compiled date: Aug 09 2017 Firmware compiled time: 03:00:00 Firmware released date: Sep 19 2017 Firmware released time: 10:36:57 SW Version: MPSS.JO.1.0.c5.7-00028-M8909EAAAANVZM- 1.59782.2.109829.1 IMEI: 358784-07-XXXXXX-X SPC: 645088 MEID: 358784072XXXXX Mobile ESN: 80396DD3 SSD_A: 0000000000000000 SSD_B: 0000000000000000 OTKSL: 740395 NAM Name: Sprint User Lock Code: 7315 Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.7.7 Software version. |
The Following 2 Users Say Thank You to shoaibrao For This Useful Post: |
12-08-2017, 08:29 | #14 (permalink) | |
Member: 2318698 Status: Offline Thanks Meter: 15 | Nice thankyou it unlocked!! But how do I active the Internet? I can't type APN and LTE/4G/3g does NOT work Quote:
The Following User Says Thank You to gayrat_gsm For This Useful Post: |
12-09-2017, 00:26 | #15 (permalink) | |
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | my phone is still locked even with new ver 2.7.7 Quote:
The Following User Says Thank You to nadirghazi For This Useful Post: |
