11-22-2017, 16:02 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. If You will try to downgrade phone's firmware version, You may damage your device. Please, read Software manual attentive: Open Hidden Menu 1. Remove SD and SIM cards from the phone; 2. Go to "Settings" -> "About phone" -> "Software information"; 3. Click on Build number 5 times; 4. Enable USB debugging ("Settings" -> "Developer options" -> "USB Debugging"); 5. Connect powered-on phone to PC via Micro USB cable; 6. Install necessary driver; 7. Click "Open Hidden Menu" button; 8. Follow software instructions (prompts). Note: To add APN, perform following steps: Go to "IOT(CDG2)" -> "LTE Setting" -> "APN Setting"; Press and hold "Recent Apps / Settings" button, then select "New APN" |
11-22-2017, 16:06 | #4 (permalink) | |
No Life Poster Join Date: Aug 2017 Location: falhala
Member: 2749393 Status: Offline Thanks Meter: 39 | Quote:
