03-21-2017, 17:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | LS775 reset FRP error -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM101 Selected model: LS775 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 22% SW Version: LS775ZV8 Mode: Emergency Initializing flash...OK SW version: LS775ZV8_07 Android version: 7.0 LAF Version: 1.1 Product ID: CT69S160728003338 IMEI: 350305-26-000000-4 Target operator: SPR Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Resetting FRP Lock... Step 1...Failed! Error code: VJAC8C0AB5 Reading partitions...OK Resetting FRP Lock...Failed! LAF Error: 80000121. Reset FRP operation is currently not supported for your phone's firmware. Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.5.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM101 Selected model: LS775 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 18% SW Version: LS775ZV8 Mode: Emergency Initializing flash...OK SW version: LS775ZV8_07 Android version: 7.0 LAF Version: 1.1 Product ID: CT69S160728003338 IMEI: 350305-26-000000-4 Target operator: SPR Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Resetting FRP Lock... Step 1...Failed! Error code: VJAC8C0AB5 Reading partitions...OK Resetting FRP Lock...Failed! LAF Error: 80000121. Reset FRP operation is currently not supported for your phone's firmware. Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.5.9 Software version. Last edited by Octopus box; 03-22-2017 at 08:51. |
03-22-2017, 08:37 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As You can see from the Software log, "Reset FRP" operation is not supported for your phone's firmware at the moment: Quote:
