05-14-2016, 15:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: Karachi
Member: 2564757 Status: Offline Sonork: 100.1673410 Thanks Meter: 27 | LS980 Diag Enable! When i'm Type this code ##3424# then open new "Service Code" tab open ! what is a Service code for this device ?? |
05-19-2016, 15:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, reflash your phone with ZV8 firmware version from the Support Area, then repeat operation which You need. |
06-07-2016, 12:36 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, read carefully: Please, reflash your phone with ZV8 firmware version from the Support Area, then repeat operation which You need. To know which firmware version is latest check and read this forum thread Firmware description |
06-08-2016, 16:14 | #5 (permalink) | |
Member: 2564757 Status: Offline Sonork: 100.1673410 Thanks Meter: 27 | Quote:
Sent from my SM-N920G using Tapatalk | |
06-10-2016, 09:18 | #6 (permalink) |
Major Poster Join Date: Jun 2016 Location: Ukraine
Member: 2582261 Status: Offline Thanks Meter: 7 | FaizanChauhaan, There are several ways to turn on diag or to know the spc: - Flash stock 4.2 firmware, then type ##443336772# in the dialer, you'll see your spc! - In Android 5 (you need root) use the ShortCut Master, type Diag in the search string, go to the last proces it finds (there should be the DIAG at the end), launch it and you'll have the diag enabled or type Chameleon, launch the first proces it finds then go to DiagMSLRequest, launch it and set the value "0", so you'll be able tu turn on DIAG without SPC by the ##DIAG# menu! -Unfortunately, I don't know the exact method on Android 4.4, but you can try ShortCut Master also! |
