02-03-2016, 16:45 | #1 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | LS990 No Data connection (try this solution) any advice how to enable data in LG LS990 all semes to be Ok SPC but phone not taking data Last edited by Octopus box; 01-13-2017 at 08:22. |
02-03-2016, 16:59 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. As i understand You have problem with mobile data on the phone, please try to set up settings manually for your mobile internet or contact to your network operator to get settings for the mobile. If problem still remain, You can try to reflash the phone with another firmware. |
02-03-2016, 17:08 | #3 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | have tired all and seems it is general proplem regading this model after IMEI Change can you investigate it please |
02-03-2016, 17:15 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We will research this problem and try to find solution. You can also try to Write QCN file and check network again, but before perform such operation, please make all backups, first. |
02-04-2016, 09:16 | #5 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Have tried to repair NVM and write QCN not works Phone got signal and you can make calls just data connection is not comming have seen Video on youtube for some one fixing it but not telling how |
02-05-2016, 15:01 | #6 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | attached the video below https://www.youtube.com/watch?v=ZRXu4njmzcg but i did not find a way to make it works |
02-09-2016, 16:17 | #8 (permalink) |
No Life Poster Join Date: May 2009 Location: USA/NY
Member: 1025079 Status: Offline Thanks Meter: 311 | There is an app that let you enable apn and setup, I will check what is the name of it. I am sure the issue you have is that there is no option to enable in setting. |
02-18-2016, 01:14 | #10 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Quote:
I think xposed framework and intelli3g was the app for 3g working but i not try it I have also facing this issue on ls980 "unable to establish an internet or data connection" Any one solve it??? Br Shahzaib Jahangir | |
01-12-2017, 21:43 | #11 (permalink) |
Crazy Poster Join Date: Jan 2012 Location: MS Repairing zone Karachi Age: 42
Member: 1712378 Status: Offline Thanks Meter: 1 | now a days i am also facing same issue no data connection , actually i flashed the ls990 using octopus, then root, repair imei, it got signal now , but no apn setting tag,,, i m thinking to use some custom rom,,, may some one suggest,,, solution |
01-13-2017, 00:41 | #12 (permalink) |
Registered User Join Date: Oct 2000 Location: CI Age: 44
Member: 2246 Status: Offline Thanks Meter: 20 | Hi! @msajjas if you experience issue with data and no apn settings try the app below Regards! |
The Following 5 Users Say Thank You to markaba For This Useful Post: |
