07-16-2016, 12:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | ls990 problem m.r octopus[Solved] help lg ls 990 phone open connecct pc no com port diag open usb debung open LS990ZV4_04.51101.oct flash try phone no comport Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: LS990 Reading info... Could not detect mode! Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Model ID: LGLS990 Firmware version: LGLS990AT-00-ZV4-SPR-US-JUN-19-2014+04 Kernel version: 3.4.0-perf-gccc9cf3-00001-g59ce002 (lgmobile@LGEARND4B12) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Thu Jun 19 19:28:43 KST 201 Android version: 4.4.2 Hardware: Qualcomm MSM8974PRO-AC ARMv7 Processor rev 1 (v7l) Fixing IMEI... New IMEI: 354348-04 Performed by 2.3.6 software version. |
07-17-2016, 05:51 | #2 (permalink) | |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | Quote:
and all instruction follow,go to cable & Manual tab All trcik Available how to flash how to repair imei How to Unlock how to read backup and etc Br, Unlockinfo | |
07-18-2016, 09:05 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Please, check in Device managed which devices are appeared, make screenshot and post here, also check that drivers are installed correctly and try to use the latest Software version | |
09-08-2016, 19:00 | #6 (permalink) |
Member: 706822 Status: Offline Thanks Meter: 647 | ok problem solved phone connect phone carging slect after com open (no mtp selected) |
The Following User Says Thank You to mathew_di For This Useful Post: |
