02-19-2017, 12:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | ls990 struck at logo after flash lg and restrt -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM119 Selected model: LS990 Reading info... Model ID: LGLS990 IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 30% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LS990ZV4_04 Android version: 4.4.2 LAF Version: 1.0 Product ID: PT02S141103000761 IMEI: 352596-06-420469-7 Target operator: spr Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS990ZV4_04.51101.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM119 Selected model: LS990 Reading info... Model ID: LGLS990 IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 45% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: Android version: 4f3d013 LAF Version: Product ID: IMEI: .0 Target operator: Hardware: Performed by 2.5.8 Software version. |
02-20-2017, 09:06 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to re-flash the phone with another firmware file from the Support Area (ZV5 or higher versions). Last edited by Octopus box; 02-20-2017 at 09:11. |
02-20-2017, 19:11 | #3 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | now phone go in secure boot error Quote:
-------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: LS990 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM119 Selected model: LS990 Reading info... Mode: Emergency Initializing flash...OK SW version: LS990ZV4_04 Android version: 4.4.2 LAF Version: 1.0 Product ID: PT02S141103000761 IMEI: 352596-06-420469-7 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS990ZV8_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.5.8 Software version. | |
02-21-2017, 05:44 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | Write ZV8 Firmware and post result! Just flashed one with ZV8 Firmware and working well! Regards .::M Irfan::. |
02-21-2017, 08:52 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
