09-21-2016, 14:48 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2080607 Status: Offline Thanks Meter: 0 | Ls991 dead -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM176 Selected model: LS991 Reading info... Model ID: LGLS991 IMEI: 357388888888888 Android version: 6.0 Battery level: 45% Mode: Emergency Initializing flash...OK SW version: LS991ZVC_01 LAF Version: 1.1 Product ID: YE05S151007003768 IMEI: 357355-06-609350-8 Target operator: SPR Hardware: rev_10 Opening "ls991zv9_12_arb02.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing factory...OK Writing system...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.3.9 software version. Connecting to server support.octoplusbox.com:82...OK Authorizing...OK |
09-21-2016, 14:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. According to the Software log, You are downgrade firmware version from ZVC to ZV9, downgrade can damage your device, please try to put the phone into Emergency mode manually, after try to reflash phone with latest firmware version, if You can't put phone into Emergency mode, You can try to repair phone with Medusa Pro Software. |
09-21-2016, 15:37 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
To enter emergency mode, power phone OFF, press and hold "Vol+" button and connect USB cable. | |
09-21-2016, 15:38 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Before perform any operation with your device, first You need to read Software manual, press Cable & Manual button: If it is not possible to write firmware or during firmware writing occures error, you need to put manualy phone into Emergency mode Note: Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. Note: Please, don't upgrade/downgrade firmware version, if it is not necessary. Also warning popup window and warning message into Software log added in latest Software version, but You used old Software version. Please always use the latest Software. Last edited by Octopus box; 09-21-2016 at 15:48. |
09-21-2016, 15:39 | #8 (permalink) | |
Also You can check out Youtube channel Youtube | |
