04-25-2017, 04:49 | #1 (permalink) |
Freak Poster Join Date: Apr 2017 Location: china
Member: 2709982 Status: Offline Sonork: 100.1677638 Thanks Meter: 1 | LS992 Write Frameware failed..,please Help me! Platform: LG Qualcomm Selected port: COM1373 Selected model: LS992 Reading info... Mode: Emergency Initializing flash...OK SW version: LS992ZV5_04 Android version: 6.0.1 LAF Version: 1.1 Product ID: PT02S160509002270 IMEI: 355602-07-255096-9 Target operator: SPR Hardware: rev_10 Performed by 2.6.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1373 Selected model: LS992 Reading info... IMEI: 350305-26-000000-4 Android version: 6.0.1 Battery level: 24% SW Version: LS992ZV3 Mode: Emergency Initializing flash...OK SW version: LS992ZV5_04 Android version: 6.0.1 LAF Version: 1.1 Product ID: PT02S160509002270 IMEI: 355602-07-255096-9 Target operator: SPR Hardware: rev_10 Reading firmware... Reading partitions...OK Selecting output file...OK Destination file: "LS992ZV5_04.oct" Selecting firmware partitions... Reading modem...OK Deleting temporary files... Deleting directory "C:\Users\ADMINI~1\AppData\Local\Temp\LS992ZV5_04\ "... Deleting file "C:\Users\ADMINI~1\AppData\Local\Temp\LS992ZV5_04\ modem"...OK Directory "C:\Users\ADMINI~1\AppData\Local\Temp\LS992ZV5_04\ " succesfully deleted! Reading firmware done! Performed by 2.6.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1373 Selected model: LS992 Reading info... Mode: Emergency Initializing flash...OK SW version: LS992ZV5_04 Android version: 6.0.1 LAF Version: 1.1 Product ID: PT02S160509002270 IMEI: 355602-07-255096-9 Target operator: SPR Hardware: rev_10 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LS992ZV5_04.oct"... Firmware file has wrong structure (error code: BCASD4BFCS). Please, redownload firmware file. If it will not help - contact to support at [email protected]led! Performed by 2.6.2 Software version. |
04-25-2017, 09:04 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, read full firmware with all partitions, then You can try to flash the file into your device at your own risk. |
04-25-2017, 09:30 | #10 (permalink) |
Member: 2709982 Status: Offline Sonork: 100.1677638 Thanks Meter: 1 | The same error... Checking data...OK Platform: LG Qualcomm Selected port: COM1361 Selected model: LS992 Reading info... IMEI: 355602-07-357703-7 Android version: 7.0 Battery level: 48% SW Version: US99223a Mode: Emergency Initializing flash...OK SW version: US99223a_03 Android version: 7.0 LAF Version: 1.1 Product ID: PT02S160727001258 IMEI: 355602-07-357703-7 Target operator: USC Hardware: rev_10 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "US99223a_03.oct"...Failed! Firmware file has wrong structure (error code: ABQP17D2PK). Please, redownload firmware file. If it will not help - contact to support at [email protected] Performed by 2.6.2 Software version. |
04-25-2017, 14:57 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have prepared test Software version for You. Please download and install it form the Support Area ("LG/TEST SOFTWARE" folder), then You can try to perform Write Firmware operation. Note again, You can damage your device, so write firmware only at your own risk. Last edited by Octopus box; 04-25-2017 at 15:08. |
