Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 10-06-2018, 08:15   #1 (permalink)
Member: 1984599
Sonork: PM For Sonork Id ;P
Thanks Meter: 37
Smile LS993 8.0 unlock question [Solved]
Checking data...OK
Platform: LG Qualcomm
Selected port: COM38
Selected model: LS993
Reading info...
IMEI: 35514XXXXXXXXX
Android version: 8.0.0
Battery level: 69%
SW Version: LS993ZVC
Mode: Emergency
Initializing flash...OK
SW version: LS993ZVC_12
LAF Version: 1.1
Product ID: PT03S170412001050
IMEI: 355140-08-155866-5
Target operator: SPR
Hardware: rev_10
Unlock operation is currently not supported for your phone's firmware.
Reading partitions...OK
Reading Carrier...OK
Unlocking...OK
Writing Carrier...
LAF Error: 80000121.
Trying second method...Failed!
LAF Error: 80000118.
Performed by 2.8.8 Software version.
Old 10-06-2018, 09:47   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 25,110
Hello.
As can You see from the Software log:
But You can try to Unlock your phone by writing the specific firmware LS993ZVA_to_AS99310c_for_unlock, LS993 will be detected as AS993 and will be unlocked.
The specific firmware can be downloaded from the folder “lg/for unlock and repair/” in the Support Area.
Old 11-05-2018, 16:32   #3 (permalink)
Member: 72939
Thanks Meter: 29
LS993ZVA_to_AS99310c did not work, LS993ZVA_to_H87315d did work. Phone is unlocked , working on LTE for T-Mobile in the USA.
The Following 2 Users Say Thank You to razor1 For This Useful Post:
Old 12-10-2018, 20:46   #4 (permalink)
Member: 327489
Thanks Meter: 55
for LS993ZVC can i downgrade with the H87315d for unlock safely?
Old 12-11-2018, 04:35   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
This is not safely, but You can try at your own risk.
Old 12-11-2018, 09:44   #6 (permalink)
siemensjunior's Avatar
Member: 1367150
Thanks Meter: 38
You can flash the last firmware for H87320h(8.0) and it will work!
The Following 2 Users Say Thank You to siemensjunior For This Useful Post:
Old 12-31-2018, 23:27   #7 (permalink)
Member: 2851359
Originally Posted by Octopus box View Post
Hello.
why can't download nothing from server ?
Old 01-01-2019, 07:35   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
What is the problem with downloading exactly? Also where are You from? Probably some necessary ports are closed by your ISP.
Old 01-01-2019, 12:07   #9 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,212
can you give me Download link H87320H i need to unlock LS993 Ver 8.0
The Following User Says Thank You to mohit_kripalu01 For This Useful Post:
Old 01-02-2019, 16:36   #10 (permalink)
Member: 1367150
Thanks Meter: 38
H87320h_00_OPEN_CA_OP_1112.kdz
The Following 6 Users Say Thank You to siemensjunior For This Useful Post:
Old 01-03-2019, 14:36   #11 (permalink)
Member: 2886601
I have limited slow bandwidth. Anyone try LS993ZVC -> ]H87320h ?
Thank you!
Old 01-03-2019, 15:58   #12 (permalink)
Member: 2758420
Thanks Meter: 2
Yes, worked with LS993ZVC 8.0
The Following 2 Users Say Thank You to Erisbel For This Useful Post:
Old 01-30-2019, 18:04   #13 (permalink)
Member: 2540144
yuo are sure bro ls993zvc to h873?
Old 02-03-2019, 01:26   #14 (permalink)
Member: 2886601
Anyone who tried this know if you're able to add & edit APNs after?
Old 02-21-2019, 17:49   #15 (permalink)
Member: 1219775
Thanks Meter: 39
Did you test yourself, or can you post flashing logs... I want to make sure
Page generated in 0.37687 seconds with 7 queries
