07-28-2017, 01:32 | #1 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2360996 Status: Offline Thanks Meter: 6 | LS997 remove FRP error, keep failing and i havent had any success on it -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM226 Selected model: VS987 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info...Canceled! Performed by 2.7.0.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM226 Selected model: LS997 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 21% SW Version: LS997ZV5 Mode: Emergency Initializing flash... Performed by 2.7.0.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM226 Selected model: LS997 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 21% SW Version: LS997ZV5 Mode: Emergency Initializing flash...Failed! Performed by 2.7.0.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM226 Selected model: LS997 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.0.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM226 Selected model: LS997 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... IMEI: 350305-26-000000-4 Android version: 7.0 Battery level: 22% SW Version: LS997ZV5 Mode: Emergency Initializing flash...OK SW version: LS997ZV7_04 Android version: 7.0 LAF Version: 1.1 Product ID: PT01S170105003815 IMEI: 359969-07-152649-8 Target operator: SPR Hardware: rev_10 Reading partitions...Failed! Performed by 2.7.0.2 Software version. |
07-28-2017, 07:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, download and install test Software version from the Support Area (LG/TEST SOFTWARE/), then repeat Reset FRP operation again, post here full Software log. |
