05-19-2020, 19:33 | #1 (permalink) |
Major Poster Join Date: Jun 2018
Member: 2843811 Status: Offline Thanks Meter: 7 | M150 Stuck at logo Reset FRP [Answered] After using Octoplus FRP Server service, Phone is bricked. Please check logs. Code: Checking data...OK Platform: LG Qualcomm Selected port: COM2762 Selected model: M150 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM150AT-01-V20p-310-410-MAR-13-2019-ARB02+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB42S180410003927 IMEI: 35XXXX-XX-XXXXXXX Target operator: ATT Hardware: rev_10 Reset FRP operation for M150 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: WXXXXXXXXXXX Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "M150_35XXXXXXXXXXXXXXX_19-05-2020_12-48-08.oct" Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable and power phone ON. 2. Complete all startup settings. 3. Power phone OFF and put it to Download mode. 4. Connect the cable then press "OK" button. Failed! Performed by 3.0.2 Software version. Reboots out of "Download Mode" When I Take It In It. Please Check Video Link For Reference. Remove Spaces. Code: https://you tu.be/ DY0q-qXDPmA |
05-20-2020, 08:06 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. You need to repeat operation onace again, what is your username, then we can add You one more attempt?! Quote:
05-20-2020, 15:51 | #3 (permalink) | |
Member: 2843811 Status: Offline Thanks Meter: 7 | Quote:
As I have mentioned in my post. Code: Checking data...OK Platform: LG Qualcomm Selected port: COM2762 Selected model: M150 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM150AT-01-V20p-310-410-MAR-13-2019-ARB02+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB42S180410003927 IMEI: 35XXXX-XX-XXXXXXX Target operator: ATT Hardware: rev_10 Reset FRP operation for M150 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: WXXXXXXXXXXX Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "M150_35XXXXXXXXXXXXXXX_19-05-2020_12-48-08.oct" Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable and power phone ON. 2. Complete all startup settings. 3. Power phone OFF and put it to Download mode. 4. Connect the cable then press "OK" button. Username : Wirelesswaves-ad | |
05-20-2020, 17:24 | #4 (permalink) |
Member: 2843811 Status: Offline Thanks Meter: 7 | How to Revive it even if I use Medusa EMMC Connections ? I am unable to find this firmware : Code: SW version: LGM150AT-01-V20p-310-410-MAR-13-2019-ARB02+0 Code: Backup saved to "M150_35XXXXXXXXXXXXXXX_19-05-2020_12-48-08.oct" |
05-22-2020, 07:43 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We're currently testing on your device to modelate same situation, but most likely You will need to repair your device with Medusa Pro Software or any other Software where this device is supported via USB or eMMC repair |
08-24-2020, 12:47 | #7 (permalink) |
Junior Member Join Date: Apr 2013 Location: Caracas Age: 48
Member: 1913876 Status: Offline Sonork: Yosward1 Thanks Meter: 5 | Checking data...19/8/2020 4:08:45 p. m. > OK 19/8/2020 4:08:45 p. m. > Platform: LG Qualcomm 19/8/2020 4:08:45 p. m. > Selected port: COM30 19/8/2020 4:08:45 p. m. > Selected model: M150 19/8/2020 4:08:45 p. m. > Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). 19/8/2020 4:08:45 p. m. > Reading info... 19/8/2020 4:08:47 p. m. > Model ID: LG-M150 19/8/2020 4:08:47 p. m. > IMEI: 3xxxx-xxxxxx-x 19/8/2020 4:08:47 p. m. > Android version: 7.0 19/8/2020 4:08:47 p. m. > Battery level: 31% 19/8/2020 4:08:48 p. m. > Mode: Emergency 19/8/2020 4:08:48 p. m. > Initializing flash...19/8/2020 4:08:49 p. m. > OK 19/8/2020 4:08:51 p. m. > Platform: msm8909 19/8/2020 4:08:51 p. m. > SW version: 19/8/2020 4:08:51 p. m. > LGM150AT-00-V20f-ATT-US-OCT-04-2017-ARB00+0 19/8/2020 4:08:51 p. m. > Android version: 7.0 19/8/2020 4:08:51 p. m. > LAF Version: 1.1 19/8/2020 4:08:51 p. m. > Product ID: CW83S171126001284 19/8/2020 4:08:51 p. m. > IMEI: 35xxxx-x9-xxxxxxx-x 19/8/2020 4:08:51 p. m. > Target operator: ATT 19/8/2020 4:08:51 p. m. > Hardware: rev_10 19/8/2020 4:08:51 p. m. > Reset FRP operation for M150 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? 19/8/2020 4:08:52 p. m. > Reading partitions...19/8/2020 4:08:53 p. m. > OK 19/8/2020 4:08:53 p. m. > Detecting writing method...19/8/2020 4:08:53 p. m. > OK 19/8/2020 4:08:53 p. m. > Resetting FRP Lock... 19/8/2020 4:08:53 p. m. > Writing loader... 19/8/2020 4:08:53 p. m. > Step 1... 19/8/2020 4:08:53 p. m. > Step 2... 19/8/2020 4:08:53 p. m. > Step 3... 19/8/2020 4:08:53 p. m. > Step 4... 19/8/2020 4:08:53 p. m. > Step 5... 19/8/2020 4:08:53 p. m. > Step 6... 19/8/2020 4:08:53 p. m. > Step 7... 19/8/2020 4:08:53 p. m. > Step 8... 19/8/2020 4:08:53 p. m. > Step 9... 19/8/2020 4:08:53 p. m. > Step 10...19/8/2020 4:08:53 p. m. > OK 19/8/2020 4:08:53 p. m. > Writing userdata... 19/8/2020 4:09:09 p. m. > Writing cmd... 19/8/2020 4:09:09 p. m. > reading cmd... 19/8/2020 4:09:09 p. m. > Read: EXEC...19/8/2020 4:09:09 p. m. > OK 19/8/2020 4:09:09 p. m. > Formating encrypt...19/8/2020 4:09:13 p. m. > OK 19/8/2020 4:09:13 p. m. > Restoring loader...19/8/2020 4:09:13 p. m. > OK 19/8/2020 4:09:13 p. m. > Resetting FRP lock successfully completed! 19/8/2020 4:09:13 p. m. > Rebooting phone... 19/8/2020 4:09:13 p. m. > To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). 19/8/2020 4:09:13 p. m. > Performed by 3.0.2 Software version. 19/8/2020 4:09:14 p. m. > Elapsed Time: 12:00:30 a. m. 19/8/2020 4:11:17 p. m. > Converting files... 19/8/2020 4:11:17 p. m. > Firmware file has wrong structure (error code: PQVZXSTOT3). Please, redownload firmware file. If it will not help - contact to support at [email protected] 19/8/2020 4:11:38 p. m. > Deleting temporary files... 19/8/2020 4:11:38 p. m. > Deleting directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\"... 19/8/2020 4:11:38 p. m. > Directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\" succesfully deleted! 19/8/2020 4:11:55 p. m. > Converting files... 19/8/2020 4:11:55 p. m. > Firmware file has wrong structure (error code: PQVZXSTOT3). Please, redownload firmware file. If it will not help - contact to support at [email protected] 19/8/2020 4:11:57 p. m. > Deleting temporary files... 19/8/2020 4:11:57 p. m. > Deleting directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\"... 19/8/2020 4:11:57 p. m. > Directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\" succesfully deleted! 19/8/2020 4:12:38 p. m. > Converting files... 19/8/2020 4:12:38 p. m. > Firmware file has wrong structure (error code: PQVZXSTOT3). Please, redownload firmware file. If it will not help - contact to support at [email protected] 19/8/2020 4:14:28 p. m. > Deleting temporary files... 19/8/2020 4:14:28 p. m. > Deleting directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\"... 19/8/2020 4:14:28 p. m. > Directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\" succesfully deleted! 19/8/2020 4:14:43 p. m. > Converting files... 19/8/2020 4:14:43 p. m. > Firmware file has wrong structure (error code: PQVZXSTOT3). Please, redownload firmware file. If it will not help - contact to support at [email protected] 19/8/2020 4:14:44 p. m. > Deleting temporary files... 19/8/2020 4:14:45 p. m. > Deleting directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\"... 19/8/2020 4:14:45 p. m. > Directory "C:\Users\RAFAEL~1\AppData\Local\Temp\LGM150AT-00-V20d-ATT-US-MAY-02-2017-ARB00+0\" succesfully deleted! |
The Following User Says Thank You to Yosward1 For This Useful Post: |
08-25-2020, 08:29 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. First of all You've used and outdated Software version 3.0.2. You should install and accept all Software updates or we'll not able to provide correct support for your issue! Second, as we can see Reset FRP operation was completred successfull, so what is the exact problem? What is the exact state of your device right now? |
