11-22-2018, 06:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Yes, please use the latest Software version from the Support Area (here is direct link for You: http://forum.gsmhosting.com/vbb/f799...-help-2517072/) and post here the result. |
11-22-2018, 07:37 | #3 (permalink) |
Junior Member Join Date: Jan 2008
Member: 679815 Status: Offline Thanks Meter: 3 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM120 Selected model: M200N Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M200n IMEI: xxxxxx Android version: 8.1.0 Battery level: 93% SW Version: M20020a Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM200nAT-00-V20a-EUR-XX-AUG-28-2018+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: CH32S170916002648 IMEI: 354965-08-402731-3 Target operator: GLOBAL Hardware: rev_10 Reset FRP operation for M200N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock... Performed by 2.8.9.10 Software version. |
11-22-2018, 08:10 | #5 (permalink) |
Member: 679815 Status: Offline Thanks Meter: 3 | its same -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM120 Selected model: M200N Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M200n IMEI: XXXXXXXXXX Android version: 8.1.0 Battery level: 91% SW Version: M20020a Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM200nAT-00-V20a-EUR-XX-AUG-28-2018+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: CH32S170916002648 IMEI: XXXX Target operator: GLOBAL Hardware: rev_10 Reset FRP operation for M200N will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock... Performed by 2.8.9.10 Software version. |
11-22-2018, 08:16 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
