03-02-2018, 15:07 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hi. As You can see from your Software log, there is the latest firmware version in your device: Quote:
You can try to downgrade firmware version at your own risk (downgrade may lead to phone damage) and then do "Reset FRP" operation. | ||
03-28-2018, 15:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Do Reset FRP via Test Point, create new thread and post there the result. Also read and always follow these rules: http://forum.gsmhosting.com/vbb/f62/...rules-1591101/, http://forum.gsmhosting.com/vbb/f62/...rules-1591101/. |
04-21-2018, 14:42 | #5 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2253202 Status: Offline Thanks Meter: 32 | Welcome to Octoplus/Octopus Box LG Software version 2.8.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM34 Selected baudrate: 0 Selected model: M400DY Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM34 Mode: Emergency Initializing flash...OK Model ID: LG-M400Y SW version: LGM400YAT-00-V10d-ZAF-XX-DEC-11-2017+0 LAF Version: 1.1 Product ID: CD21S170403000587 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 355959-08-005575-7 IMEI B: 350305-26-000000-1 Bluetooth address: A8:B8:6EE:82:CC Wi-Fi MAC address: A8:B8:6E:39:07:AB SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reset FRP operation for M400DY will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.3 Software version. Done. Last edited by Octopus box; 04-21-2018 at 18:43. |
10-18-2018, 09:04 | #6 (permalink) |
Junior Member Join Date: Mar 2006 Location: Pasay,Metro Manila Philippines Age: 43
Member: 239430 Status: Offline Thanks Meter: 1 | lg octopus frp tool 1.2.8 not supported lg m400dy version 7.0 security level august 08,2018 please give solution for this method thanxs |
