09-22-2018, 22:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1207202 Status: Offline Thanks Meter: 44 | MP260 unlock problem [Answered] try to unlock frist faild i restart mobile and try again opration done but phone still locked frist qu phone ver11c can flash 10r or10t from support second if i try to unlock again will take anther100 credits Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Connecting to server ...OK Username: ddaaaa Authorizing...OK Checking balance...OK Your balance: 200 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM373 Selected model: MP260 Reading info...Failed! Port busy Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM780 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 354446-09-986481-8 Android version: 7.0 Battery level: 3% SW Version: MP26011c Trying to enable Diagnostics ports... Found model LGMP260A: ?h at port COM780 Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM780 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 354446-09-986481-8 Android version: 7.0 Battery level: 3% SW Version: MP26011c Mode: Normal Firmware compiled date: May 22 2018 Firmware compiled time: 04:00:00 Firmware released date: Jun 7 2018 Firmware released time: 10:19:09 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1.146190.1 IMEI: 354446-09-986481-8 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Phone is not rooted. Please, root the phone manually! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM373 Selected model: MP260 Reading info...Failed! Port busy Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM780 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 354446-09-986481-8 Android version: 7.0 Battery level: 3% SW Version: MP26011c Mode: Normal Firmware compiled date: May 22 2018 Firmware compiled time: 04:00:00 Firmware released date: Jun 7 2018 Firmware released time: 10:19:09 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1.146190.1 IMEI: 354446-09-986481-8 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: ddaaaa Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 100 credits. Sending exploit...OK Executing exploit...OK Sending data to server... Step 1.b...Failed! Unlock Failed Please, reboot the phone and try again. Rebooting phone... Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: xxxx Authorizing...OK Checking balance...OK Your balance: 200 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM373 Selected model: MP260 Reading info...Failed! Port busy Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM780 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 354446-09-986481-8 Android version: 7.0 Battery level: 3% SW Version: MP26011c Mode: Normal Firmware compiled date: May 22 2018 Firmware compiled time: 04:00:00 Firmware released date: Jun 7 2018 Firmware released time: 10:19:09 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1.146190.1 IMEI: 354446-09-986481-8 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 100 credits. Sending exploit...OK Executing exploit...OK Sending data to server... Step 1.b...Failed! Unlock Failed Please, reboot the phone and try again. Rebooting phone... Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM780 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 354446-09-986481-8 Android version: 7.0 Battery level: 3% SW Version: MP26011c Mode: Normal Firmware compiled date: May 22 2018 Firmware compiled time: 04:00:00 Firmware released date: Jun 7 2018 Firmware released time: 10:19:09 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1.146190.1 IMEI: 354446-09-986481-8 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 100 credits. Sending exploit...OK Executing exploit...OK Sending data to server...OK Calculating. Please Wait...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM780 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 354446-09-986481-8 Android version: 7.0 Battery level: 3% SW Version: MP26011c Mode: Normal Firmware compiled date: May 22 2018 Firmware compiled time: 04:00:00 Firmware released date: Jun 7 2018 Firmware released time: 10:19:09 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1.146190.1 IMEI: 354446-09-986481-8 SPC: 000000 Performed by 2.8.0 Software version. Last edited by Octopus box; 09-23-2018 at 09:58. |
09-23-2018, 09:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We have refunded 100 credits to your account, please check your balance. Try to re-flash the device, do Factory Reset, root it again and repeat the "Unlock" operation. Post here the result. |
09-23-2018, 14:00 | #3 (permalink) |
Member: 1207202 Status: Offline Thanks Meter: 44 | phone frist have frp i try octopus failed as its ver 11c octopus frp do it i think problem in ver but i am fraid to flash ver10 i dont need phone brick what ver you recommed to safe flash |
