10-18-2017, 02:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | MS210 Reset FRP done Platform: LG Qualcomm Selected port: COM358 Selected model: MS210 Reading info... Model ID: LGMS210 IMEI: 353662-08-671153-8 Android version: 7.0 Battery level: 93% SW Version: MS21010r Mode: Emergency Initializing flash...OK SW version: LGMS210AT-02-V10r-310-160-SEP-04-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CY22S170120002819 IMEI: 353662-08-671153-8 Target operator: MPCS Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "MS21010i_00_0407.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing modem...OK Writing aboot...OK Writing abootbak...OK Writing tz...OK Writing tzbak...OK Writing sbl1...OK Writing sbl1bak...OK Writing rpm...OK Writing rpmbak...OK Writing devcfg...OK Writing devcfgbak...OK Writing cmnlib...OK Writing cmnlibbak...OK Writing cmnlib64...OK Writing cmnlib64bak...OK Writing keymaster...OK Writing keymasterbak...OK Writing dsp...OK Writing sec...OK Writing apdp...OK Writing msadp...OK Writing boot...OK Writing laf...OK Writing lafbak...OK Writing recovery...OK Writing recoverybak...OK Writing factory...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing persist...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 2.7.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM358 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LGMS210 IMEI: 353662-08-671153-8 Android version: 7.0 Battery level: 94% SW Version: MS21010i Mode: Emergency Initializing flash...OK SW version: LGMS210AT-02-V10i-310-160-APR-07-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CY22S170120002819 IMEI: 353662-08-671153-8 Target operator: MPCS Hardware: rev_10 Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.7.6 Software version. i flash file from support and then do frp reset then it work 100% Last edited by Octopus box; 10-18-2017 at 06:24. |
The Following User Says Thank You to shawn4life For This Useful Post: |
