04-16-2015, 02:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | MS395 can't connect [Solved] i use the original sim card but still fail to connect. drivers already install try on two pc but no connection i using win 7 & win 8 Last edited by Octopus box; 04-18-2015 at 06:54. |
04-16-2015, 05:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To connect the device in Normal Mode, do the next: 1. Install the latest drivers: http://octoplusbox.com/files/drivers...Ver_3.12.3.exe. 2. Connect the phone directly to PC motherboard USB port via LG P999 cable with 910 kOhm resistor inside, not via standart Micro USB cable. Don't use any USB hubs, this is important. 3. Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering". 4. Press "Read phone info" button in the Software. |
04-16-2015, 21:50 | #3 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | yes i install that drivers and use 910 kOhm P999 cable i try 3 cables but while try to on "USB tetherig" have error while waiting to activate any other options? |
04-17-2015, 06:04 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Btw, what action do You want to perform with the phone exactly? Unlock or repair IMEI? What is the problem with your phone? | |
04-17-2015, 21:56 | #5 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
i try to unlock remove sim card and on "USB tethering" its need to install sim card for using USB tethering thanks | |
04-17-2015, 23:13 | #6 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | without on "USB terthing" while connect to PC setting>Developer options>Verify apps over USB if check then uncheck and check again then its install drivers and now phone connect and unlock Code: Welcome to Octoplus/Octopus Box LG Software version 1.9.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM10 Selected model: MS395 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM10 Selected model: MS395 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM13 Selected model: MS395 Reading info...OK Mode: Normal Model ID: MS395 Firmware compiled date: Jul 21 2014 Firmware compiled time: 11:00:00 Firmware released date: Sep 14 2014 Firmware released time: 10:30:25 SW Version: MPSS.DI.2.0.1.c1.15-00021-M8926DAAAANAZM-1 IMEI: 355197-06-550898-3 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: MS395 Reading info...OK Mode: Normal Model ID: MS395 Firmware compiled date: Jul 21 2014 Firmware compiled time: 11:00:00 Firmware released date: Sep 14 2014 Firmware released time: 10:30:25 SW Version: MPSS.DI.2.0.1.c1.15-00021-M8926DAAAANAZM-1 IMEI: 355197-06-550898-3 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "MS395_355197065508983_18-04-2015_10-53-17.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "MS395_355197065508983_18-04-2015_11-02-23.SEC" Writing security area...OK Switching to Normal mode... Found model MS395 at port COM13 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
