11-27-2016, 09:03 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: heart of Asia
Member: 311316 Status: Offline Thanks Meter: 41 | Need H791 16gb 32gb files wit android 6.0 [Solved] after frp H791 sw damaged flashed with E:\FF\LG\H791\lgh791at-00-v20a-nxs-jul-22-2016-16g-nrd90mfe-user+0.oct now wifi not work, mac address damaged both 02.00.00.00 tried repair but not successful need 6.0 version LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E-US LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-32G-MDA89E-US Last edited by Octopus box; 01-10-2018 at 06:33. |
11-28-2016, 08:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, post here full Software log, we will check it. You can try to reflash your phone with Nexus Root Tool kite (firmware for your device You can download with Nexus Root Tool kite). |
12-18-2016, 23:46 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: Hungary Age: 55
Member: 4695 Status: Offline Thanks Meter: 15 | no wifi Hi, I have a same problem, I recovered the frp on h791 sucess, and updated it via wifi then after upr process still in recovery andr logo, then flashed via lgh791at-00-v20a-nxs-jul-22-2016-16g-nrd90mfe-user+0.oct and now doesn't work the wifi, mac address damaged 02.00.00.00 the BT worked fine. here is the logs: Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\18-12-2016_13-48-20.log" created. 2016. 12. 18. 13:48:26 > Welcome to Octoplus/Octopus Box LG Software version 2.5.4 2016. 12. 18. 13:49:45 > -------------------------------------------------------------------------------- 2016. 12. 18. 13:49:45 > Checking data...2016. 12. 18. 13:49:46 > OK 2016. 12. 18. 13:49:46 > Platform: LG Qualcomm 2016. 12. 18. 13:49:46 > Selected port: COM1 2016. 12. 18. 13:49:46 > Selected model: H791 2016. 12. 18. 13:49:46 > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 2016. 12. 18. 13:49:46 > Reading info...2016. 12. 18. 13:49:59 > Failed! 2016. 12. 18. 13:49:59 > Could not detect mode! 2016. 12. 18. 13:49:59 > Performed by 2.5.4 Software version. 2016. 12. 18. 13:56:23 > -------------------------------------------------------------------------------- 2016. 12. 18. 13:56:23 > Checking data...2016. 12. 18. 13:56:24 > OK 2016. 12. 18. 13:56:24 > Platform: LG Qualcomm 2016. 12. 18. 13:56:24 > Selected port: COM4 2016. 12. 18. 13:56:24 > Selected model: H791 2016. 12. 18. 13:56:24 > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 2016. 12. 18. 13:56:24 > Reading info... 2016. 12. 18. 13:56:26 > Model ID: LGH791 2016. 12. 18. 13:56:26 > IMEI: 353627-xx-xxxxxx-x 2016. 12. 18. 13:56:26 > Android version: 2016. 12. 18. 13:56:26 > Battery level: 69% 2016. 12. 18. 13:56:26 > SW Version: 2016. 12. 18. 13:56:26 > LGH791AT-00-V10i-NXS-XXX-OCT-2 2016. 12. 18. 13:56:28 > Mode: Emergency 2016. 12. 18. 13:56:28 > Initializing flash...2016. 12. 18. 13:56:31 > OK 2016. 12. 18. 13:56:32 > SW version: 2016. 12. 18. 13:56:32 > LGH791AT-00-V10i-NXS-XXX-OCT-23-2015-16G-MDB08L-USER+0 2016. 12. 18. 13:56:32 > Android version: 6.0 2016. 12. 18. 13:56:32 > LAF Version: 1.2 2016. 12. 18. 13:56:32 > Product ID: BS08S151114000451 2016. 12. 18. 13:56:32 > IMEI: 353627-xx-xxxxxx-x 2016. 12. 18. 13:56:32 > Target operator: GOOGLE 2016. 12. 18. 13:56:32 > Hardware: 2016. 12. 18. 13:56:32 > After performing Reset FRP operation the phone may stuck on logo. To fix this problem You shall reflash the phone with the latest firmare. Perform Reset FRP operation at your own risk. Continue? 2016. 12. 18. 13:56:34 > Reading partitions...2016. 12. 18. 13:56:36 > OK 2016. 12. 18. 13:56:36 > Resetting FRP Lock...2016. 12. 18. 13:56:36 > OK 2016. 12. 18. 13:56:36 > Resetting screen lock successfully completed! 2016. 12. 18. 13:56:36 > Performed by 2.5.4 Software version. -------------------------------------------------------------------------------------- 2016. 12. 18. 15:55:28 > Checking data...2016. 12. 18. 15:55:29 > OK 2016. 12. 18. 15:55:29 > Platform: LG Qualcomm 2016. 12. 18. 15:55:29 > Selected port: COM6 2016. 12. 18. 15:55:29 > Selected model: H791 2016. 12. 18. 15:55:29 > Reading info... 2016. 12. 18. 15:55:32 > Model ID: LGH791 2016. 12. 18. 15:55:32 > IMEI: 353627-xx-xxxxxx-x 2016. 12. 18. 15:55:32 > Android version: 2016. 12. 18. 15:55:32 > Battery level: 52% 2016. 12. 18. 15:55:32 > SW Version: 2016. 12. 18. 15:55:32 > LGH791AT-00-V10i-NXS-XXX-OCT-2 2016. 12. 18. 15:55:34 > Mode: Emergency 2016. 12. 18. 15:55:34 > Initializing flash...2016. 12. 18. 15:55:36 > OK 2016. 12. 18. 15:55:37 > SW version: 2016. 12. 18. 15:55:37 > LGH791AT-00-V10i-NXS-XXX-OCT-23-2015-16G-MDB08L-USER+0 2016. 12. 18. 15:55:37 > Android version: 6.0 2016. 12. 18. 15:55:37 > LAF Version: 1.2 2016. 12. 18. 15:55:37 > Product ID: BS08S151114000451 2016. 12. 18. 15:55:37 > IMEI: 353627-xx-xxxxxx-x 2016. 12. 18. 15:55:37 > Target operator: GOOGLE 2016. 12. 18. 15:55:37 > Hardware: 2016. 12. 18. 15:55:37 > -------------------------------------------------------------------------------- 2016. 12. 18. 15:55:37 > Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! 2016. 12. 18. 15:55:38 > -------------------------------------------------------------------------------- 2016. 12. 18. 15:55:39 > Opening "lgh791at-00-v20a-nxs-jul-22-2016-16g-nrd90mfe-user+0 (1).oct"...2016. 12. 18. 15:55:39 > OK 2016. 12. 18. 15:55:39 > Setting options...2016. 12. 18. 15:55:41 > OK 2016. 12. 18. 15:55:41 > Reading partitions...2016. 12. 18. 15:55:43 > OK 2016. 12. 18. 15:55:43 > Formating USERDATA...2016. 12. 18. 15:55:47 > OK 2016. 12. 18. 15:55:47 > Writing PrimaryGPT...2016. 12. 18. 15:55:48 > OK 2016. 12. 18. 15:55:48 > Writing modem...2016. 12. 18. 15:57:16 > OK 2016. 12. 18. 15:57:16 > Writing pmic...2016. 12. 18. 15:57:17 > OK 2016. 12. 18. 15:57:17 > Writing sbl1...2016. 12. 18. 15:57:19 > OK 2016. 12. 18. 15:57:19 > Writing tz...2016. 12. 18. 15:57:20 > OK 2016. 12. 18. 15:57:20 > Writing sdi...2016. 12. 18. 15:57:21 > OK 2016. 12. 18. 15:57:21 > Writing hyp...2016. 12. 18. 15:57:22 > OK 2016. 12. 18. 15:57:22 > Writing rpm...2016. 12. 18. 15:57:23 > OK 2016. 12. 18. 15:57:23 > Writing aboot...2016. 12. 18. 15:57:25 > OK 2016. 12. 18. 15:57:25 > Writing sbl1bak...2016. 12. 18. 15:57:27 > OK 2016. 12. 18. 15:57:27 > Writing pmicbak...2016. 12. 18. 15:57:28 > OK 2016. 12. 18. 15:57:28 > Writing tzbak...2016. 12. 18. 15:57:29 > OK 2016. 12. 18. 15:57:29 > Writing hypbak...2016. 12. 18. 15:57:30 > OK 2016. 12. 18. 15:57:30 > Writing rpmbak...2016. 12. 18. 15:57:31 > OK 2016. 12. 18. 15:57:31 > Writing abootbak...2016. 12. 18. 15:57:33 > OK 2016. 12. 18. 15:57:33 > Writing sec...2016. 12. 18. 15:57:34 > OK 2016. 12. 18. 15:57:34 > Writing persist...2016. 12. 18. 15:57:41 > OK 2016. 12. 18. 15:57:41 > Writing imgdata...2016. 12. 18. 15:57:45 > OK 2016. 12. 18. 15:57:45 > Writing laf...2016. 12. 18. 15:58:10 > OK 2016. 12. 18. 15:58:10 > Writing keymaster...2016. 12. 18. 15:58:11 > OK 2016. 12. 18. 15:58:11 > Writing cmnlib...2016. 12. 18. 15:58:12 > OK 2016. 12. 18. 15:58:12 > Writing keymasterbak...2016. 12. 18. 15:58:13 > OK 2016. 12. 18. 15:58:13 > Writing cmnlibbak...2016. 12. 18. 15:58:14 > OK 2016. 12. 18. 15:58:14 > Writing boot...2016. 12. 18. 15:58:33 > OK 2016. 12. 18. 15:58:33 > Writing recovery...2016. 12. 18. 15:58:58 > OK 2016. 12. 18. 15:58:58 > Writing vendor...2016. 12. 18. 16:03:04 > OK 2016. 12. 18. 16:03:04 > Writing cache...2016. 12. 18. 16:03:11 > OK 2016. 12. 18. 16:03:11 > Writing system...2016. 12. 18. 16:52:35 > OK 2016. 12. 18. 16:52:35 > Writing BackupGPT...2016. 12. 18. 16:52:36 > OK 2016. 12. 18. 16:52:36 > Reading partitions...2016. 12. 18. 16:52:38 > OK 2016. 12. 18. 16:52:38 > Formating RCT...2016. 12. 18. 16:52:38 > Failed! 2016. 12. 18. 16:52:38 > Formating MPT...2016. 12. 18. 16:52:38 > Failed! 2016. 12. 18. 16:52:38 > Finalizing...2016. 12. 18. 16:52:40 > OK 2016. 12. 18. 16:52:40 > Writing firmware done! 2016. 12. 18. 16:52:40 > Performed by 2.5.4 Software version. the factory firmw. not helped (unlocked BL. !) I think a full backup maybe help for me. BR, Keni |
12-19-2016, 08:46 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @Keni You can try to reflash your phone with Nexus Root Tool kit (firmware for your device You can download with Nexus Root Tool kit). Last edited by Octopus box; 12-19-2016 at 09:21. |
12-20-2016, 14:52 | #6 (permalink) |
Member: 4695 Status: Offline Thanks Meter: 15 | wlan Hi, I found the solution: How to Fix the Wi-Fi Problem After Updating to Android 7.0 Nougat (Nexus 5X) The ota update erase the wlan_mac.bin, (these idiots over there?)(google developers),,, I'm happy now. BR, Keni |
