Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 09-10-2014, 19:38   #1 (permalink)
Member: 2251086
NEED HELP with D820 for repair the imei
I tried to fix the imei but somehow the software said failed due cant see the device... I need help...
Old 09-10-2014, 19:57   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
Please post here full Software log of "Repair IMEI" operation.
Old 09-10-2014, 20:34   #3 (permalink)
Member: 2251086
Welcome to Octoplus/Octopus Box LG Software version 1.6.8
Platform: LG Qualcomm
Selected port: COM3
Selected model: D820
Reading info...Failed!
Could not detect mode!
that where failed.
Old 09-10-2014, 20:49   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please do the next:
1. Reinstall "LG United Mobile Driver v 3.8.1" and "LG Android ADB Driver" drivers.
2. Disconnect the phone and all third-party devices from PС.
3. Enable USB debugging in the phone ("Settings" -> "Developer options" -> "USB Debugging");
3. Repeat "Repair IMEI" operation (You should accept all software requests on phone's screen, so, be attentive).
4. Carefully follow Software instructions.
Also note:
After performing Unlock or Repair IMEI operations for D820 and D821,
3G network will become unavailable (2G networks will still work).
At the moment developers are working on the solution on how to activate 3G.
If you wish to return your device to the previous state, before it was unlocked
or had IMEI repaired, just write first security and NVM backups to the device.
Old 09-10-2014, 21:20   #5 (permalink)
Member: 2251086
Selected port: COM3
still same result
Old 10-29-2014, 05:43   #6 (permalink)
Member: 2255194
Welcome to Octoplus/Octopus Box LG Software version 1.7.3
Selected port: COM4
Selected port: COM4
Reading info...
Initializing ADB...OK
ADB Server was found. Trying to kill...
Waiting for phone...Failed!
Please, reconnect phone, enable USB debugging, and try again.
To enable USB debugging, please perform the following steps:
1. Disconnect cable
2. Install LG Android ADB drivers
3. Go to "Settings" -> "About phone" -> "Software information"
4. Click on Build number 5 times
5. Enable "Settings" -> "Developer options" -> "USB debugging" option
6. Connect the cable and check, whether ADB interface has appeared in
PC Device Manager.
Selected port: COM4
Selected port: COM4
Selected port: COM4
Old 10-29-2014, 08:17   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Disconnect all other devices from PC, re-boot the PC, re-start the phone, turn ON USB Debugging Mode in the phone, install LG Android ADB drivers, and connect the device again.
To enable USB Debugging Mode, please perform the following steps:
1. Disconnect the cable.
2. Install LG Android ADB drivers.
4. Click on Build number 5 times.
5. Enable "Settings" -> "Developer options" -> "USB debugging" option.
6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.
Page generated in 0.17210 seconds with 8 queries
