08-13-2016, 17:04 | #1 (permalink) |
Major Poster Join Date: Dec 2010
Member: 1471420 Status: Offline Thanks Meter: 4 | Need help unlocking LG-K371 AT&T Phoenix 2 [Solved] ------------------------------------ Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: K371 Reading info... Model ID: LG-K371 IMEI: ************** Android version: 6.0 Battery level: 47% Mode: Normal Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items... --------------------------------------------------- Last edited by Octopus box; 08-15-2016 at 11:03. |
08-13-2016, 17:14 | #2 (permalink) | |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Quote:
Remove SD and SIM cards from the phone; Connect powered-on phone to PC with Micro USB cable; Install necessary driver; Click "Unlock" button; Follow software instructions (prompts). Note: To connect the phone in Normal Mode, do one of the following: Enable "USB Debugging" mode; Type 277634#*# or *#546368#*371# for coresponding Android version 5.x or 6.x, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". | |
The Following User Says Thank You to onz For This Useful Post: |
08-13-2016, 17:23 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to enabled "Skip Read/Write QCN during Unlock operation" option, then repeat "Unlock" operation. Also, please use the latest Software version. |
08-13-2016, 17:58 | #4 (permalink) |
Member: 1471420 Status: Offline Thanks Meter: 4 | set the Port Check Test to Enabled and issue solved. Thanks to onz quick reply. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: K371 Reading info... Model ID: LG-K371 IMEI: ************** Android version: 6.0 Battery level: 55% Mode: Normal Firmware compiled date: Feb 14 2016 Firmware compiled time: 23:00:00 Firmware released date: Mar 4 2016 Firmware released time: 16:54:50 SW Version: MPSS.JO.1.0.c5.7-00014-M8909EAAAANVZM-1.44108.1 IMEI: *********** SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "K371_354885073081925_13-08-2016_12-30-21.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "K371_354885073081925_13-08-2016_12-37-05.SEC" Switching to Normal mode... Found model LGK371AT: ÿh `, at port COM9 Writing security area...OK Rebooting phone... Found model LGK371AT: ÿh `, at port COM9 Phone successfully unlocked! Please, reboot the phone manually. Performed by 2.3.7 software version. |
The Following User Says Thank You to nasser4life For This Useful Post: |
