07-01-2014, 01:11 | #1 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2214373 Status: Offline Thanks Meter: 0 | Need help Using Octopus with LG phones [Solved] |
07-01-2014, 06:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please post here full Software log with all of your actions, we need to see, which actions You have performed exactly with the device. |
07-01-2014, 17:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | To connect and unlock the device, do the next: 1. Disconnect all other devices from PC. 2. Re-boot the PC. 3. Remove SD and SIM cards from the phone. 4. Enable USB Debugging Mode ("Settings" -> "Developer options" -> "USB Debugging"). 5. Connect the powered on phone to PC via Micro USB cable. 6. Install the necessary driver. 7. Go to "Settings -> PC connection -> USB connection type -> Select USB Connection method" and select "LG Software" ("PC Software"). 8. Click the "Unlock" button. 9. Follow software instructions (promts). |
07-01-2014, 19:06 | #5 (permalink) |
Member: 2214373 Status: Offline Thanks Meter: 0 | It worked It worked, just an fyi in the software steps it did not say this step Go to "Settings -> PC connection -> USB connection type -> Select USB Connection method" and select "LG Software" ("PC Software"). I appreciate your help Thank you |
