06-09-2015, 17:02 | #1 (permalink) |
Major Poster Join Date: Sep 2010 Location: Islamic Republic Of Iran
Member: 1387838 Status: Offline Sonork: 100.1605493 Thanks Meter: 3 | Need to LG-D335 Persian flash file plz share to me flash file of this model on support octapous box. LG-D335 i need to persian flash file of this model or any language is exist at model. tnx |
06-09-2015, 18:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Unfortunately we don't have firmwares for D335 at the moment. We will try to find firmwares for this model and as we do, they will be available in the Support Area. |
06-10-2015, 10:40 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Firmwares for LG D335 are now available in the Support Area. |
06-10-2015, 16:14 | #4 (permalink) | |
Member: 1387838 Status: Offline Sonork: 100.1605493 Thanks Meter: 3 | Quote:
but when i flashed with this file d335_v10f_00.oct i see this error on screen plz help me. Code: -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 921600 Selected model: D335 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Phone found. Mode: Emergency Initializing flash...OK Model ID: LG-D335 SW version: LGD335AT-00-V10f-AME-XX-JAN-22-2015+0 LAF Version: 1.1 Product ID: YE03S150124006413 IMEI: 356417-06-582787-1 Target operator: GLOBAL Hardware: rev_11 Battery level: 100% Opening "d335_v10f_00.oct"...OK Setting options...OK Reading partition... Formating USRDATA...OK Writing MBR...Failed! | |
06-10-2015, 16:27 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What was exact state of the phone before You've tried to reflash it? What is current state of the phone? Is phone entering Emergency Mode? Last edited by Octopus box; 06-10-2015 at 16:33. |
06-10-2015, 16:34 | #6 (permalink) | |
Has updated its user reset after the update was stuck on the logo Last edited by shahab_ex2002; 06-10-2015 at 16:44. | |
06-10-2015, 17:29 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please check your PM, we have sent You test Software version. Try to perform "Write Firmware" operation with test Software and post here results with full Software log. |
06-10-2015, 17:44 | #8 (permalink) | |
not resolved. Code: Welcome to Octoplus/Octopus Box LG Software version 1.9.7.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 921600 Selected model: D335 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Phone found. Mode: Emergency Initializing flash...OK Model ID: LG-D335 SW version: LGD335AT-00-V10f-AME-XX-JAN-22-2015+0 LAF Version: 1.1 Product ID: YE03S150124006413 IMEI: 356417-06-582787-1 Target operator: GLOBAL Hardware: rev_11 Battery level: 97% Opening "d335_v10f_00.oct"...OK Setting options...OK Reading partition... Formating USRDATA...OK Writing MBR...Failed! | |
06-10-2015, 18:11 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We will check where can be the problem and will notify You about possible solution. |
