02-23-2015, 10:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Nexsus 5 (downgrade /repair) guide D820 If you are on android 5.0 etc .. Than follow the steps below ( I am assuming you have already installed Lg drivers) 1- Go to https://developers.google.com/android/nexus/images Search for (Factory Images "hammerhead" for Nexus 5 (GSM/LTE)) 2-Download (4.4.4 (KTU84P)) 3-Unzip it using 7zip you will get this (If there is no adb fastboot ..put into this folder manually) 4-Turn off your mobile and connect it with usb using volume down button It wil show boot loader..Check if boot loader is locked or unlocked ..If locked first unlock it using adb "fastboot oem unlock".. 5-Open flash-all.bat and wait for 5 minutes.. You have a mobile on andorid 4.4.4. |
The Following User Says Thank You to zishhaider For This Useful Post: |
02-23-2015, 10:30 | #2 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | D821 D821 Guide how to flash [Tutorial] How to flash factory images with LG Flashtool [ Nexus 5 ] LG Flash Tool with dll d821 lg flashtool plus d821 dll - Download - 4shared - zish haider android 4.4 firmware Listing of D821 |
02-23-2015, 10:41 | #3 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | How to repair Now when you are below 5.0 android. You are ready to unlock or repair No need to root .. Octopus will do it automatically .. May users have been facing problem in connecting nexsus 5 to octopus software .. 1-enable usb debug (Always install lg drivers from support if repair fails while installing driver delay than do it from start again) 2- always put your eyes on screen of mobile to allow adb connection (tick always) 3-Do not untick qcn read and write as it will avoid no network issue (until you are an expert ) 4-still facing problem than connect it into boot loader mode and do repair function.. 5-Give it some time.. Don't try to do it quickly. Here take a look at this thread (Last post) http://forum.gsmhosting.com/vbb/f799...epair-1900120/ @Mod if it is useful kindly add it to sticky thread list Br Zish |
