10-29-2014, 15:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | nexsus 5 ime repair failed Code: Welcome to Octoplus/Octopus Box LG Software version 1.7.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 16GB Device serial number: 050c3255f0dd8a01 Hardware: rev_11 Bootloader lock state: unlocked After perform Repair IMEI operation, 3G/4G network will be unavailable! Fixing IMEI... New IMEI: 350606-20-489586-6 Reading QCN... Send SPC...Failed! Backup saved to "D820_Bad_29-10-2014_19-11-39.qcn" -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 16GB Device serial number: 050c3255f0dd8a01 Hardware: rev_11 Bootloader lock state: unlocked -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 16GB Device serial number: 050c3255f0dd8a01 Hardware: rev_11 Bootloader lock state: unlocked After perform Repair IMEI operation, 3G/4G network will be unavailable! Fixing IMEI... New IMEI: 350606-20-489586-6 Reading QCN... Send SPC...Failed! Backup saved to "D820_Bad_29-10-2014_19-12-09.qcn" |
10-29-2014, 15:46 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As You can see from your Software log, your device is connected in Fastboot Mode, not in Normal Mode: Quote:
10-29-2014, 15:52 | #3 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | sorry my mistake.. i was trying in download mode... normal mode Code: Welcome to Octoplus/Octopus Box LG Software version 1.7.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 16GB Device serial number: 050c3255f0dd8a01 Hardware: rev_11 Bootloader lock state: unlocked After perform Repair IMEI operation, 3G/4G network will be unavailable! Fixing IMEI... New IMEI: 350606-20-489586-6 Reading QCN... Send SPC...Failed! Backup saved to "D820_Bad_29-10-2014_19-11-39.qcn" -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 16GB Device serial number: 050c3255f0dd8a01 Hardware: rev_11 Bootloader lock state: unlocked -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info...OK Mode: Fastboot Model ID: hammerhead D820(H) 16GB Device serial number: 050c3255f0dd8a01 Hardware: rev_11 Bootloader lock state: unlocked After perform Repair IMEI operation, 3G/4G network will be unavailable! Fixing IMEI... New IMEI: 350606-20-489586-6 Reading QCN... Send SPC...Failed! Backup saved to "D820_Bad_29-10-2014_19-12-09.qcn" -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 After perform Repair IMEI operation, 3G/4G network will be unavailable! Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ:ÿh°? at port COM413 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°? Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 IMEI: 358239-05-739788-9 SPC: 293611 Fixing IMEI... New IMEI: 350606-20-489586-6 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading Roaming List 1...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D820_358239057397889_29-10-2014_19-25-13.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D820_358239057397889_29-10-2014_19-38-03.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Failed! |
10-30-2014, 18:40 | #6 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Problem solved.. downgrade to 4.4.3 no root no cwm(octopas will do it).. just disable antivirus (in case of exploit detection as virus) repair ime.. follow instructions as given.. after repair is done.. do not insert sim card other wise it will keep rebooting for network.. just press repair 3g 4g button.. nd you are done.. |
