07-09-2014, 09:34 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: all device sell hear
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | nexus 5 imei repair done -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: D821 Reading info...Failed! Port busyFailed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM6 Selected model: D821 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 After perform Repair IMEI operation, 3G/4G network will be unavailable! Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ:ÿh°? at port COM152 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°? Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 IMEI: 352136-06-839538-9 Fixing IMEI... New IMEI: 3566666 Reading NVM...OK Backup saved to "D821_35213_09-07-2014_14-05-35.NVM" Reading EFS...OK Backup saved to "D821_3529_09-07-2014_14-09-12.EFS" Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually 3. Connect cable and press "Ok" buttonFailed! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM6 Selected model: D821 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM6 Selected model: D821 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM6 Selected model: D821 Reading info... -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM34 Selected model: D821 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 After perform Repair IMEI operation, 3G/4G network will be unavailable! Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ:ÿh°? at port COM152 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°? Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 IMEI: 3528-9 Fixing IMEI... New IMEI: 3 Reading NVM...OK Backup saved to "D821_357-2014_14-16-35.NVM" Reading EFS...OK Backup saved to "D821_3514_14-21-25.EFS" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D821_352_09-07-2014_14-22-02.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Select "Yes" on phone screen and press "Power" button. Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°G at port COM152 Checking data...OK Writing NVM...OK NVM succesfully repaired. Writing EFS...OK IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
07-16-2014, 11:22 | #3 (permalink) |
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | |
07-20-2014, 17:27 | #4 (permalink) |
Junior Member Join Date: May 2014
Member: 2193198 Status: Offline Thanks Meter: 0 | everyone's log shows that 3G/4G repair was done successfull but on the device it still doesnt work. thats why banziitox24 is asking. its because on some of the D820 models this repair doesnt work (even though log stats it does). Babu has a D821 which works more commonly than D820 |
