09-16-2019, 10:11 | #1 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2507280 Status: Offline Thanks Meter: 1 | not unlock by serever this helpp [Solved] Note: To connect the phone in Normal Mode, do the next: Select "File transfer" mode in "Use USB connection for" window, then press "Always"; Type 277634#*# or *#546368#*260# or 3845*#260#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". Welcome to Octoplus/Octopus Box LG Software version 2.9.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM305 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 355266-08-710836-9 Android version: 7.0 Battery level: 93% Mode: Normal Firmware compiled date: May 27 2017 Firmware compiled time: 13:00:00 Firmware released date: Aug 17 2017 Firmware released time: 19:03:33 SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1 IMEI: 355266-08-710836-9 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. |
09-16-2019, 12:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, download and install the latest Software version re-read Software manual attentive, cehck that all drivers are installed correctly and repeat Unlock operation |
09-16-2019, 17:39 | #3 (permalink) |
Member: 2507280 Status: Offline Thanks Meter: 1 | Welcome to Octoplus/Octopus Box LG Software version 2.9.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM305 Selected model: MP260 Reading info... Model ID: LGMP260 IMEI: 355266-08-710836-9 Android version: 7.0 Battery level: 68% Trying to enable Diagnostics ports... Found model LGMP260A: ÿh at port COM305 Checking root access... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Pashai55 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Sending data to server... Sending exploit...OK Executing exploit...OK Calculating. Please Wait...OK Calculating. Please Wait...OK Executing exploit...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.9.5 Software version. |
