Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 11-29-2018, 14:51   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 99,792
Post 🐙 Octoplus/Octopus Box LG Software 2.9.0 is out! 🐙
Octoplus/Octopus Box LG Software version 2.9.0 is out!
Added Unlock operation for M150 V20x, X210CM/APM, Sprint LS992 ZVC/ZVD/ZVE/ZVF, LS993 ZV9/ZVA and more!
Octoplus/Octopus Box LG Software v.2.9.0 Release Notes:
🐙 Added "Unlock" (via server, requires 50 credits) for the latest security type/firmware versions for the following devices:
- M150
- M151
- M153
- M154
- LMX210APM, LMX210CM
- LMX410CS
Added "Unlock"* (via server, requires 50 credits) for the following devices:
- LS992 (ZVC, ZVE, ZVD, ZVF firmware versions)
- LS993 (ZV9, ZVA firmware versions)
*Note: after unlocking you can perform Factory Data Reset operation via phone's menu, or update firmware and the device will remain unlocked.
If you perform "Wipe" operation via recovery mode, phone's security will be reset and the device will get back to locked state!
🐙 Added support for the following models:
- LMX210FM - added Direct Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
- LMX210HM - added Direct Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
- LMX210ZM - added Direct Unlock, Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash
- DM-02H - added Read/Write Firmware (thanks to Mr. lerner)
- AS375 - added added Repair IMEI, Write Firmware, Reset FRP, Read/Write/Reset Security, Read/Write QCN, Read/Write NVM, Read Full Flash (thanks to Mr. asadnow2k)
🐙 Improved "Reset FRP" operation for SP200 and SP320.
🐙 Improved "Reset FRP" operation via "Qualcomm...9008" Mode for LG G6 and V30 series.
🐙 All supported operations are described in details in Software manual ("Cable & Manual" button in Software)
Download Octoplus/Octopus Box LG v.2.9.0
Find out more at: www.octoplusbox.com
The Following 39 Users Say Thank You to Gsmserver For This Useful Post:
Old 11-29-2018, 15:14   #2 (permalink)
Member: 1984825
Thanks Meter: 83
great update ....ineed root for lg lm-x210ma to unlock it with my favorite box octopus ...please provide me the root
thx br
Old 11-29-2018, 15:32   #3 (permalink)
lyes_albert's Avatar
Member: 2669781
Thanks Meter: 1,572
Hi, thanks for this awesome update..
I reckon, adding custom flashing is enormously important, at least if the firmware built is incompatible, the phone won't be set dead, boot-loader areas will be skipped.
Also, the ability to un-tick the Preloader Partition in MTK based LG phones is necessary.
Thanks so much...
The Following User Says Thank You to lyes_albert For This Useful Post:
Old 11-29-2018, 16:08   #4 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,649
Hi, please post model exactly and firmware version....
thx br
Old 11-29-2018, 16:16   #5 (permalink)
Member: 2117327
Thanks Meter: 40
Hello, after Unlock ls992, ls993 vía credits its possible add apn?
Old 11-29-2018, 16:18   #6 (permalink)
MDxavi's Avatar
Member: 1882912
Sonork: 100.1677703
Thanks Meter: 228
no solution for APN yet
Old 11-29-2018, 16:26   #7 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 550
so what if we boot device then do hard reset from menu then give customer back THEN customer decided to do factory reset in recovery,will the device relock or we have to use only menu option all the time
THANKS FOR YOUR HARD WORK
Old 11-29-2018, 16:39   #8 (permalink)
Crazy Poster
Member: 2636022
Thanks Meter: 13
please add LG-G710PM Srint unlock!!!
Old 11-29-2018, 16:47   #9 (permalink)
MDxavi's Avatar
Member: 1882912
Sonork: 100.1677703
Thanks Meter: 228
temporary solution better than nothing
Old 11-29-2018, 17:01   #10 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 23,741
Hello.
No, unfortunately no solution at the moment.
Old 11-29-2018, 17:02   #11 (permalink)
ppdavisito's Avatar
Member: 1840836
Sonork: 100.1659703
Thanks Meter: 129
thx br
Bro this is the root tested in the last security
https://forum.xda-developers.com/and...-root-t3746425
Old 11-29-2018, 17:13   #12 (permalink)
Member: 1562568
Unlock error lg lmx210CM
Connecting to server...OK
Octopus smart card is present.
Checking smart card...OK
Username: ..................
Authorizing...OK
Checking balance...OK
Checking operation...OK
Get credits, needed for current operation...OK
Your balance: 54 credits.
To perform "Unlock" operation you need to have 50 credits.
Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk.
Continue?
Reading QCN...
Send SPC...OK
Reading Mobile Property...OK
Reading Feature Mask...OK
Reading Roaming List 0...Failed!
Reading NV_Numbered Items...OK
Reading NV_Numbered SIM1 Items...OK
Reading NV_Numbered SIM2 Items...OK
Reading NV Items...
Performed by 2.9.0 Software version.
Old 11-29-2018, 17:43   #13 (permalink)
lucky999's Avatar
Member: 1643797
Thanks Meter: 136
i need support for LM-X410ASR
The Following User Says Thank You to lucky999 For This Useful Post:
Old 11-29-2018, 17:49   #14 (permalink)
Member: 2766438
Thanks Meter: 7
Cant understand
Iam some feeling stupid, i cant understand, why box functions what was all time free, now cost money. 50 credits for unlock 992 and 993? I buy box for work with sprint models because this work was free. Additional misunderstood, why 50 credits for no working unlock? Who need phone without working data?
I know that tmobile must unlocked via server, so credits for this can be accepted, but here pay for what? In future we will no need box? Pay for everything, and get?
The Following 5 Users Say Thank You to maximalesh For This Useful Post:
Old 11-29-2018, 18:06   #15 (permalink)
Member: 1984825
Thanks Meter: 83
hi brother lg aristo >2 LM-X210MA version 7.1.2
thx bro
Page generated in 0.45063 seconds with 7 queries
