02-07-2015, 13:37 | #17 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | I can purchase it for you but you have to pay because I'm not in mobile sale purchase business neither it is my type of work... |
02-11-2015, 10:10 | #19 (permalink) | |
Insane Poster Join Date: Mar 2004 Age: 43
Member: 57024 Status: Offline Thanks Meter: 4 | Quote:
octopus is the best but now no spuuort LS660 and ls885 . I can send you the LG offices software ,i wish you add to octopus. if you need the flash flie,PM me thx Last edited by Winner58; 02-16-2015 at 09:25. Reason: user details removed | |
02-11-2015, 10:58 | #20 (permalink) |
Member: 57024 Status: Offline Thanks Meter: 4 | Welcome to Octoplus/Octopus Box LG Software version 1.8.4 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM22 Selected model: D620 Reading info...OK Mode: Normal Model ID: LS660ZV4:ÿjÕ Incompatible model ID! Please, select correct model! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM22 Selected model: D620 Reading info...OK Mode: Normal Model ID: LS660ZV4:ÿjÕ Incompatible model ID! Please, select correct model! |
02-16-2015, 20:51 | #27 (permalink) | |
Freak Poster Join Date: Nov 2013 Location: remotely
Member: 2063388 Status: Offline Thanks Meter: 80 | Quote:
u cannot root this device when its lock by mcafee because of kill switch. so u have to think smart. try to go to setting, in setting> guest> set a code for guest after it turn on guest option. than restart your device, before comming mcafee put the petern as guest... after this u have to go again in administration, at that time u will see mcafee will not come, and u can easily goto the mcafee app, after going on set your number as a buddy number, after setting buddy number, turn your phone off, insert sim and start it again. macafee will again apear... at that time click on send the code to buddy, proceed it. this code will be applicable for an hour, so if u got the buddy code, after geting pin code u have to change the pic code to new one... after doing this procedure mcafee pin will be change.. and u can use this device hope you got my point, you dont need to root your device | |
02-20-2015, 08:00 | #28 (permalink) |
Freak Poster Join Date: Jan 2006 Location: surat
Member: 219420 Status: Offline Thanks Meter: 78 | whats a problem i try 2 firmware and convrt kdz to oct 2nd convert tot to oct my phone is live but touch celebretion is rong and reboot auto D802 32 gb Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: D802 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-D802 SW version: LGD800AT-01-V10d-310-410-AUG-14-2013+0 LAF Version: 1.0 Product ID: BS09S131222000474 IMEI: 3572************ Target operator: OPEN Hardware: rev_10 Battery level: 53% Opening "D80220D_00 refurb.oct"...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Waiting for phone... Found model D802 at port COM24 Setting Mini OS Status to 2...Failed! |
