04-17-2017, 16:52 | #16 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Dhahran ph
Member: 334094 Status: Online Sonork: none Thanks Meter: 73 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM66 Selected model: K520DY Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-K520DY IMEI: 357952-07 Android version: 6.0.1 Battery level: 100% SW Version: K52010f Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10f-ESA-XX-DEC-20-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT01S160710000591 IMEI: 357952-07 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...OK Resetting FRP lock successfully completed! Performed by 2.6.2 Software version. |
The Following User Says Thank You to ian_ramos For This Useful Post: |
04-18-2017, 13:25 | #18 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 55
Member: 60178 Status: Offline Thanks Meter: 30 | good work please i cant download soft from support i have this message an error occorred during download please try again detail impossible to connect Boot-Loader v2.0 - cell phone firmware repository pley give us an other link thanks |
04-18-2017, 14:08 | #19 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Boot-loader v.2.0 - this is not Support Area. To goes into the Support Area, press "Go to support" button on "Support & options" tab of the Software. Also You can use "Files Downloader" on "Support & options" tab of the Software to browse, search and download files from the Support Area. Or download firmwares using bittorrent support - press "Go to torrent support" button on "Support & options" tab of the Software. |
04-26-2017, 12:29 | #26 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. If You have phone in hands, download and install test Software version form the Support Area ("LG/TEST SOFTWARE" folder), then select M200n in the list and perform the operation, which You need. Post here the result. Last edited by Octopus box; 04-26-2017 at 15:56. |
