10-24-2017, 10:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Lg h961n error -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM4 Selected model: H961N Reading info... Could not detect mode! Performed by 2.7.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM103 Selected model: H961N Reading info... Model ID: LG-H961N IMEI: 353829-07-154229-9 Android version: 6.0 Battery level: 27% SW Version: H961N20f Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20f-SEA-XX-FEB-17-2017+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE02S160109003663 IMEI: 353829-07-154229-9 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "H961N_V20h_00_0818.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...Failed! LAF Error: 80000121. Please re-flash phone with the latest firmware from the support area. Performed by 2.7.5 Software version. |
10-25-2017, 08:22 | #3 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
-------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM103 Selected model: H961N Reading info... Model ID: LG-H961N IMEI: 353829-07-154229-9 Android version: 6.0 Battery level: 44% SW Version: H961N20f Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20f-SEA-XX-FEB-17-2017+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE02S160109003663 IMEI: 353829-07-154229-9 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "H961N20t_00_1215.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing hypbak...OK Writing tzbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.7.5 Software version. lg logo only after flash also | |
10-25-2017, 09:28 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If You have flashed the device with different firmwares and problem still remain, most likely it's HW issue. Also You can try to reflash the phone with original flasher. |
