11-10-2017, 15:25 | #19 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | H635 Write Firmware done Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "h635_v10b_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing sbl1...OK Writing tz...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing cust...OK Writing factory...OK Writing modem...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.7.7 Software version. Last edited by Octopus box; 11-10-2017 at 15:42. |
The Following User Says Thank You to orhan5 For This Useful Post: |
11-13-2017, 10:55 | #23 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | LG K120 Unlock successfully done LG K120 Unlock successfully done Code: Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K120E Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM83 Mode: Emergency Initializing flash...OK Model ID: LG-K120E SW version: LGK120EAT-01-V10l-EUR-XX-SEP-24-2016+0 LAF Version: 1.2 Product ID: CB46S161213000349 IMEI: 357137-07-876477-5 Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 357*********** Bluetooth address: 5C:AF:06:D8:2E:1D Wi-Fi MAC address: 5C:AF:06:45:BD:D5 -------------------------------------------------------------------------------- Reading security area...OK Backup saved to "K120E_357137*******_13-11-2017_13-08-27.EEP" Unlocking... Writing security area...OK Phone successfully unlocked! Performed by 2.7.7 Software version. Last edited by Octopus box; 11-13-2017 at 11:14. |
The Following User Says Thank You to nahidroman For This Useful Post: |
11-26-2017, 19:31 | #27 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | hello octoplus team please give update for FRP unlocking of LG-M700DSK android 7.x.x I have unlocked , software says it is fully unlocked, But still the same there is no time for hard resetting via settings log: Welcome to Octoplus/Octopus Box LG Software version 2.7.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM250 Selected model: M700DSK Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M700DSKM70010f IMEI: 000000-00-000000-0 Android version: 7.1.1 Battery level: 93% SW Version: M70010f Mode: Emergency Initializing flash...OK SW version: LGM700DSKAT-00-V10f-IND-XX-SEP-08-2017-64G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: YE05S171007000672 IMEI: 358755-08-418297-8 Target operator: GLOBAL Hardware: rev_12 Reset FRP operation for M700DSK will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.7.7 Software version. |
The Following User Says Thank You to technomak For This Useful Post: |
11-27-2017, 07:38 | #28 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Yes, unfortunately, Reset FRP is currently not supported for Android 7.1.1 firmwares for this device. As soon as solution will be ready, we will release it. |
