05-24-2018, 15:24 | #1 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | 🐙 Octoplus/Octopus Box LG v.2.8.5 - FRP Unleashed 🐙 Octoplus/Octopus Box LG v.2.8.5 is out! Added world's first Reset FRP solution (from Download Mode) for the wide range of LG devices!Once again, in this update we present one more unique world's first Reset FRP solution (from Download Mode) for a wide range of LG devices! From now on, “Reset FRP” operation is supported for all available firmware versions and for all security patch levels! There is no need in risky firmware downgrade - all operations can be performed directly! Octoplus/Octopus Box LG Software v.2.8.5 Release Notes: 🐙 Released new world's first unique Reset FRP solution (from now on, these operations work for all firmware versions and latest security patch levels) for the following devices: - M700, M700A, M700AN, M700AR, M700B, M700DSK, M700DSN, M700F, M700H, M700B, M700TV, M700Y, M700Z 🐙 Added support for the following models: * After writing the specific firmware “LS993ZVA_to_H87315d_for_unlock.oct”, LS993 will be detected as H873 and will be unlocked. Note, that after writing the specific firmware, some device features, like CDMA connection will not work! Also note, that this firmware was tested on LS993 with the currently latest ZVA firmware version, so if you have another firmware version on your device, write the specific firmware at your own risk only! The specific firmware can be downloaded from the folder “lg/for unlock and repair/” in the Support Area.- X210CM - added Direct unlock, Repair IMEI, Reset FRP, Write Firmware, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash ** After writing the specific firmware “LS998V20a_to_US998V10d_for_unlock.oct”, device will be detected as US998 and will be unlocked. Note, that this firmware was tested on LS998 with the latest V20a firmware version, so if you have another firmware version on your device, write the specific firmware at your own risk only! The specific firmware can be downloaded from the folder “lg/for unlock and repair/” in the Support Area. 🐙 Some adjustments and improvements were made. 🐙 All supported operations are described in details in Software manual ("Cable & Manual" button in Software) Download Octoplus/Octopus Box LG v.2.8.5 Find out more at: www.octoplusbox.com |
The Following 55 Users Say Thank You to Gsmserver For This Useful Post: |
05-24-2018, 16:00 | #4 (permalink) |
Freak Poster Join Date: May 2014 Location: Dhaka Bangladesh Age: 34
Member: 2179298 Status: Offline Sonork: 100.1660353.Aslam Thanks Meter: 215 | Octopus Box LG v.2.8.5 Added world's first Reset FRP solution (from Download Mode) Yes It's Really Good News, Thank You So Much Gsmserver Team....For, Reset FRP solution (from Download Mode). |
The Following 3 Users Say Thank You to aslam hossain For This Useful Post: |
05-25-2018, 05:20 | #14 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Please look at “lg/for unlock and repair/” folder: Quote:
