Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 07-04-2013, 17:06   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 84,737
Post Octoplus/Octopus Box LG v1.1.8 - LG E440, E440G, E445
Octoplus/Octopus Box LG v1.1.8 is out!
Added world's first full support for:
LG E440F
Added support for:
LG E440, LG E440G, LG E445
Octoplus/Octopus Box LG Software v1.1.8 Release Notes
  • Added support for the following models:
- LG E440F - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address,
- LG E440F - Write Firmware, Read/Write/Repair EEPROM, Read Full Flash, Read Phone Info.
- LG E440 - added Direct Unlock (world's first), Read Codes, Repair IMEI, Repair BT Address,
- LG E440 - Write Firmware, Read/Write/Repair EEPROM, Read Full Flash, Read Phone Info.
- LG E440G - added Direct Unlock (world's first), Read Codes, Repair IMEI, Repair BT Address,
- LG E440G - Write Firmware, Read/Write/Repair EEPROM, Read Full Flash, Read Phone Info.
- LG E445 - added Direct Unlock (world's first), Read Codes, Repair IMEI (A/B), Repair BT Address,
- LG E445 - Write Firmware, Read/Write/Repair EEPROM, Read Full Flash, Read Phone Info.
  • Added software manuals for supported phones.
  • Released some improvements to the main software.
Dear users, as you've already might noticed, Octopus and Octoplus software are compatible with each other.
Thus, we've decided to merge Octopus and Octoplus LG/Samsung programs in order to reduce the number of
software and avoid any misunderstandings in the future. Owners of mentioned above boxes should use the
same installer. Also all Octopus Box owners can use Octoplus Shell software with all its servicing features.
Octoplus/Octopus is always step ahead bringing you world's first ideas for your professional appliance!
Download Octoplus/Octopus Box LG v1.1.8
Find out more at: www.octoplusbox.com
The Following 27 Users Say Thank You to Gsmserver For This Useful Post:
Old 07-04-2013, 18:03   #2 (permalink)
Member: 1773901
Thanks Meter: 9
thanx good update best tool lg
Old 07-04-2013, 18:08   #3 (permalink)
netmobile's Avatar
Member: 746276
Sonork: 100.1609752
Thanks Meter: 686
The service software isn't available on the server.
"Not Found Error: The requested address '/files/octoplusbox.com/softs/install_octoplus_octopus_LG_1.1.8.exe' was not found on this server".
Old 07-04-2013, 18:40   #4 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,141
@ netmobile
Hello.
Yes, You are right, we will fix the link. Now You can download setup from Free Octopus/Octoplus Support Area (press "Go to Support" button on "Support & Options" tab in software) or from here: install_octoplus_octopus_LG_1.1.8.exe.
Old 07-04-2013, 18:47   #5 (permalink)
Member: 894224
Thanks Meter: 84
Not Found
Error: The requested address '/files/octoplusbox.com/softs/install_octoplus_octopus_LG_1.1.8.exe' was not found on this server.
Old 07-04-2013, 19:21   #6 (permalink)
mubashar757's Avatar
Member: 1702642
Sonork: 100.1638878
Thanks Meter: 85
plz add lg u400 unlock ......................
Old 07-04-2013, 19:49   #7 (permalink)
Member: 1896924
Sonork: 10122012
Thanks Meter: 5
thanx gooooooooooooooood update
Old 07-04-2013, 19:52   #8 (permalink)
netmobile's Avatar
Member: 746276
Sonork: 100.1609752
Thanks Meter: 686
Originally Posted by Octopus box View Post
@ netmobile
Hello.
Unfortunately, I cannot enter to support area because I am a Dreambox SE user with Octopus LG activated, and everytime I click on "Go to support" an error occurs:
Welcome to Octoplus/Octopus Box LG Software version 1.1.7
Connecting to server octopus-server0.no-ip.biz:82... OK
Authorizing... Failed!
Connecting to server octopus-server0.no-ip.biz... Failed!
Could not connect to the server!
By other hand, I downloaded the service software via the external link which you've provided.
Old 07-04-2013, 20:04   #9 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,778
Have tryed from OCTOPUS/PLUS SHELL SW?, i think u can downloader from the SHELL, go in ADMINISTRATOR OF HELPS and try from here,
allumts
Old 07-04-2013, 20:18   #10 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 531
the version Octopus 1.1.8 have a packet or virus inside, i have installed setup.exe?? now i have a virus, i cant download last version!
i must do exclution in my anti virus? all is ok with 1.1.7 version
check file for download please! maybe (you have virus in server)
br
polaco
Old 07-04-2013, 20:32   #11 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,778
br
polaco
@ el-polaco, i've downloaded from the link mediafire above and Avira not detect virus, strange , becouse for more Update or files from various BOX always detect Virus.
I've installed IoBit and Anvanced System Care and have solved many problem of False Positive, however from the link above not detect Virus,
Old 07-04-2013, 22:20   #12 (permalink)
el-polaco's Avatar
Member: 1057178
Thanks Meter: 531
Hi!
From Mediafire Link download ok! but in oficcial site have a Advice Potencially file called (setup.exe)
Using AVG + Zemana Anti-Keylogger
Polaco
Old 07-04-2013, 22:24   #13 (permalink)
netmobile's Avatar
Member: 746276
Sonork: 100.1609752
Thanks Meter: 686
br
polaco
I checked the setup.exe with Avast, and the antivirus doesn't found anything.
Old 07-04-2013, 22:38   #14 (permalink)
el-polaco's Avatar
Member: 1057178
Thanks Meter: 531
what for is this files (setup.exe) because the soft octopus have other name...and yes, setup.exe have a problem!
solved for me. but is not safe
br
polaco
Old 07-05-2013, 06:20   #15 (permalink)
ernie78's Avatar
Member: 1229604
Sonork: 100.1602688 CSTooL
Thanks Meter: 4,642
please fix download link
br
Page generated in 0.44426 seconds with 7 queries
