01-07-2015, 15:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | octopus box card error [Answered] SN:00021xxx i have change box, dongle also but same My card is damage where i got new card for replace in india? View image: octpus ThankQ Last edited by Octopus box; 01-08-2015 at 12:05. |
01-08-2015, 07:31 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the problem with your card exactly? As we can see from your screenshot, Software is running with the card. Or You can't update the card? Please, contact to our managers in on-line Sales Chat at GsmServer, they will help You. |
01-08-2015, 09:56 | #3 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Everything works properly but i am scare that my card will damage only 4 limit left I want to active for Samsung but if my card will damage then? now put my smart-card to infinity box My octopus box is not working Should i active my box for samsung? is it safe? - LG (ver 2.3) Creating secure connection... Secure connection established. Prepairing to write card firmware... Requesting firmware... OK Writing card firmware... OK Card firmware successfully updated! Searching for server... Trying connect to server support.octoplusbox.com:4000... Server is online Server greeting: "Card updates server v.2.2" Testing connection... OK Checking validity... OK Checking your cards... Searching installed cards... Found card with s/n 00021xxx The card is valid card (e-gate). Activations: LG Selected card: 0000021xxx Updates count: 38 Updates limit: 42 Activations: - LG (ver 2.3) Creating secure connection... Secure connection established. Prepairing to write card firmware... Requesting firmware... OK Writing card firmware... OK Card firmware successfully updated! Last edited by Octopus box; 01-08-2015 at 12:05. |
01-08-2015, 10:30 | #4 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Or if buy new Samsung box can u transfer my lg activation to my Samsung new box? is yes pls let me know so i buy new box for Samsung because no one have smart card in India to replace my damage card ThankQ |
01-08-2015, 12:10 | #5 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
01-08-2015, 16:31 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to clean card's contacts, connect Box to another motherboard USB port (don't use any USB hubs or PCI USB extention cards) and run Software again. Try to connect the Box to another PC and run the Software. |
11-29-2019, 11:49 | #10 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2033479 Status: Offline Thanks Meter: 0 | Hello. I am using an octopus box Samsung and LG activated version. I have bought Frp activation code. i am now having a problem while attempting to activation the frp tool. i the box log says... Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 01078*** The card is not valid card. Found 0 cards. Please, check if the cards are inserted and all software that are working with the cards are closed I i am urgently in need of your help. thank you. |
11-29-2019, 13:38 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, remove card from box, clean all contacts, insert back into box and try to update card again, if problem still remain, remove card from box, insert into another card reader, dongle and try to update card. |
