08-01-2017, 14:09 | #1 (permalink) |
Junior Member Join Date: Jan 2007
Member: 432213 Status: Offline Thanks Meter: 0 | Octopus box card not found problem |
08-01-2017, 15:52 | #3 (permalink) |
Member: 432213 Status: Offline Thanks Meter: 0 | I installed the driver you advised me but the same message still appears. I already cleaned the smart card, I verified that everything is well placed. Here is the system log: Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 0008AB74 Selected card: 000008AB74 Updates count: 19 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - FULL (ver 2.5) - JTAG (ver 2.5) Creating secure connection... Requesting firmware... Writing card firmware... Card firmware successfully updated! Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 0008AB74 Selected card: 000008AB74 Updates count: 20 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - FULL (ver 2.5) - JTAG (ver 2.5) Creating secure connection... Requesting firmware... Writing card firmware... Card firmware successfully updated! Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 0008AB74 Selected card: 000008AB74 Updates count: 21 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - FULL (ver 2.5) - JTAG (ver 2.5) Creating secure connection... Requesting firmware... Writing card firmware... Card firmware successfully updated! Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 0008AB74 Selected card: 000008AB74 Updates count: 22 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - FULL (ver 2.5) - JTAG (ver 2.5) Activation string checking failed! Please, contact to Your reseller. Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 0008AB74 Selected card: 000008AB74 Updates count: 22 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - FULL (ver 2.5) - JTAG (ver 2.5) Creating secure connection... Requesting firmware... Writing card firmware... Card firmware successfully updated! Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 0008AB74 Selected card: 000008AB74 Updates count: 23 Updates limit: 31 Activations: - LG - FULL (ver 2.5) - Samsung - FULL (ver 2.5) - JTAG (ver 2.5) Creating secure connection... Requesting firmware... Writing card firmware... Failed! Error at cmd #4 Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found 0 cards. Please, check if the cards are inserted and all software that are working with the cards are closed Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found 0 cards. Please, check if the cards are inserted and all software that are working with the cards are closed Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found 0 cards. Please, check if the cards are inserted and all software that are working with the cards are closed Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found 0 cards. Please, check if the cards are inserted and all software that are working with the cards are closed |
08-01-2017, 16:02 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | There's no need to manually update the card. Please try to use different USB ports of PC motherboard for connection of the box. If problem will remain the same on different ports - remove the card from the box, connect it via external smart card reader (dongle) and try to run the Software again. |
