Octopus Box User Manual & FAQ Q: What is Octopus box? Q: How to use LG Qualcomm language editor?Octopus Box registration 1. Connect Octopus Box to PC. 2. Launch Octopus Box Software. 3. In the language and country field choose your interface language and country. 4. Click “OK”. The card update wizard will appear. 5. Click “Next” and follow wizard instructions. Problems with registration If your Octopus Box Software copy won’t register, please send an e-mail to [email protected]. with the description of the problem and the update wizard log attached. The log is located in C:\Program Files\GsmServer\Octopus\LOG Support & options http://www.freeimagehosting.net/uploads/0ff2529465.png To access support options and software configuration, choose “Support & Options” at the top of the program window (element 1). Finding a phone model To find a phone model, choose the model name in the “Phone Model” field (element 2) and click “Select” (element 3). You will be taken to the corresponding tab. Changing interface language To change the language of the program interface, use the “Language” select (element 4). Log window The Log window shows instructions for your further steps and progress of operations (element 5). Phone connection status In the left hand bottom corner you may see your phone current connection status (element 6). Octopus card serial number In the left hand bottom corner you can see your Octopus card serial number (element 7). Operation progress (element 8) “Show hints” on/off button (element 9) Use this button to enable or disable information tooltips. Firmware converter (element 10) Use this button to convert original firmware to Octopus box format. Octopus card update wizard. To launch Octopus card update wizard, click “Update Wizard” (element 11). Octopus Box Software update To get the link to the latest version of Octopus Box Software, click “Update Software” (element 12). Support zone To access Octopus Box Software file Support zone, click “Go to support” (element 13). To ensure correct work of Octopus Box Software, use only PC internal ports. Do NOT use USB hubs or extension cords! Working with phones based on Analog Device Microcontrollers http://www.freeimagehosting.net/uploads/0a89918e04.png Connecting the phone 1. Select “LG Analog devices” in the Octopus Box Software window (element 1). 2. Select phone model (element 2). 3. Select the COM port Octopus Box is connected to (element 3). 4. Select COM port baud rate (element 4). 5. Connect the phone to Octopus Box using a cable (to check the cable type, click “Cable: ХХХХ”) (element 5). 6. Click “Connect” and follow program instructions (element 6). Writing firmware to the phone 1. Connect the phone as explained above. 2. Select the firmware file compatible with your phone (element 7). 3. To erase user data from the phone, check “Erase flash before writing firmware” (element 8). 4. Click “Write Firmware” and follow program instructions (element 9). Reading Cal data, Full Flash and EEPROM files 1. Connect the phone as explained above. 2. To read the Cal. data file, click “Read Cal. data” (element 10). 3. To read the Full Flash file, click “Read Full Flash” (element 11). 4. To read the EEPROM file, click “Read EEPROM” (element 12). Writing Cal. data, Full Flash and EEPROM files 1. Connect the phone as explained above. 2. To write the Cal. data file, click “Write Cal. data” (element 13). 3. To write the Full Flash file, click “Write Full Flash” (element 14). 4. To write the EEPROM file, click “Write EEPROM” (element 15). Unlocking the phone 1. Connect the phone as explained above. 2. Click “Unlock” (element 16). Reading phone information 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Click “Read phone info” (element 17). Factory reset 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Click “Factory reset” (element 18). Fixing IMEI serial number 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Enter the original 14 digit IMEI serial number in the corresponding field (element 19). 3. Click “IMEI Fix” (element 20). Converting firmware 1. Octopus Box Software uses its own type of files (.oct). You can use files from the Support zone or convert native LG flash files to the “.oct” type using the built-in converter. To convert firmware from the original format to “.oct”, click “Firmware converter” (element 21). Working with phones based on Infineon Microcontrollers http://www.freeimagehosting.net/uploads/ab438e1d80.png Connecting the phone 1. Select “LG Infineon” in the Octopus Box Software window (element 1). 2. Select phone model (element 2). 3. Select the COM port Octopus Box is connected to (element 3). 4. Select COM port baud rate (element 4). 5. Connect the phone to Octopus Box using a cable (to check the cable type, click “Cable: ХХХХ”) (element 5). 6. Choose COM or USB connection (element 6). 7. Click “Connect” and follow program instructions (element 7). Writing firmware to the phone 1. Connect the phone as explained above. 2. Select the firmware file compatible with your phone (element 8). 3. Click “Write Firmware” and follow program instructions (element 9). Reading Full Flash and EEPROM files 1. Connect the phone as explained above. 2. To read the Full Flash file, click “Read Full Flash” (element 10). 3. To read the EEPROM file, click “Read EEPROM” (element 11). Writing Full Flash и EEPROM files 1. Connect the phone as explained above. 2. To write the Full Flash file, click “Write Full Flash” (element 12). 3. To write the EEPROM file, click “Write EEPROM” (element 13). Reading unlock codes 1. Connect the phone as explained above. 2. Click “Read codes” (element 14). Unlocking the phone 1. Connect the phone as explained above. 2. Click “Unlock” (element 15). Reading phone information 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Click “Read phone info” (element 16). Factory reset 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Click “Factory reset” (element 17). Fixing the IMEI serial number 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Enter the original 14 digit IMEI serial number in the corresponding field (element 18). 3. Click “IMEI A Fix” (element 19). 4. For a dual SIM card phone, enter the second IMEI(element 20). 5. Click “IMEI B Fix” (element 21). Converting firmware 1. Octopus Box Software uses its own type of files (.oct). You can use files from the Support zone or convert nativeLG flash files to the “.oct” type using the built-in converter. To convert firmware from the original format to “.oct”, click “Firmware converter” (element 22). Working with phones based on Texas Instrument Microcontrollers http://www.freeimagehosting.net/uploads/f19eb94ce1.png Connecting the phone 1. Select “LG Texas Instruments” in the Octopus Box Software window (element 1). 2. Select phone model (element 2). 3. Select the COM port Octopus Box is connected to (element 3). 4. Select COM port baud rate (element 4). 5. Connect the phone to Octopus Box using a cable (to check the cable type, click “Cable: ХХХХ”) (element 5). 6. Choose COM or USB connection (element 6). 7. Click “Connect” and follow program instructions (element 7) Writing firmware to the phone 1. Connect the phone as explained above. 2.Select the firmware file compliant with your phone (element 8). 3.Click “Write Firmware” and follow program instructions (element 9). Reading Full Flash and EEPROM files 1. Connect the phone as explained above. 2. To read the Full Flash file, click “Read Full Flash” (element 10). 3. To read the EEPROM file, click “Read EEPROM” (element 11). Writing Full Flash и EEPROM files 1. Connect the phone as explained above. 2. To write the Full Flash file, click “Write Full Flash” (element 12). 3. To write the EEPROM file, click “Write EEPROM” (element 13). Reading unlock codes 1. Connect the phone as explained above. 2. Click “Read codes” (element 14). Unlocking the phone 1. Connect the phone as explained above. 2. Click “Unlock” (element 15). Reading the phone information 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Click “Read phone info” (element 16). Factory reset 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Click “Factory reset” (element 17). Fixing the IMEI serial number 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Enter the original 14 digit IMEI serial number in the corresponding field (element 18). 3. Click “IMEI Fix” (element 19). Converting firmware 1. Octopus Box Software uses its own type of files (.oct). You can use files from the Support zone or convert native LG flash files to the “.oct” type using the built-in converter. To convert firmware from the original format to “.oct”, click “Firmware converter” (element 20). Working with phones based on Qualcomm Microcontrollers http://www.freeimagehosting.net/uploads/8e6ec0d8d3.png Connecting the phone 1. Select “LG Qualcomm” in the Octopus Box Software window (element 1). 2. Connect the phone to Octopus Box using a cable (to check the cable type, click “Cable: ХХХХ”) (element 2). 3. Click “Read the information” (element 3). Writing firmware to the phone 1. Connect the phone as explained above. 2.Select the firmware file compliant with your phone (element 4). 3. Click “Write Firmware” and follow program instructions (element 5). Dumping RAM 1.Connect the phone as explained above. 2.The option “Dump RAM” allows dumping phone memory (element 6). Reading NVM file 1. Connect the phone as explained above. 2. To read the NVM file, click “Read NVM” (element 7). Writing NVM file 1. Connect the phone as explained above. 2.To write the NVM file, click “Write NVM” (element 8). Unlocking the phone 1. Connect the phone as explained above. 2. Click “Unlock” (element 9). Restoring Security zone from the backup 1. Connect the phone as explained above. 2. Click “Restore from backup” (element 10). Repairing NVM 1. Connect the phone as explained above. 2. Click “Repair NVM” (element 11). Repairing Security zone 1. Connect the phone as explained above. 2. Click “Repair Security zone” (element 12). Repairing the Bluetooth serial number 1. Connect the phone as explained above. 2. Enter 6 hexadecimals of your phone original Bluetooth serial number in the corresponding field (element 13). 3. Click “Repair BT” (element 14). Fixing the IMEI serial number 1. Make sure the phone is on and connect it to Octopus Box as explained above. 2. Enter the original 14 digit IMEI serial number in the corresponding field (element 15). 3.Click “IMEI Fix” (element 16). Repairing the country 1. Select the country of purchase (element 17). 2. Click “Repair country” (element 18). Converting firmware 1. Octopus Box Software uses its own type of files (.oct). You may use files from the Support zone or convert native LG flash files to the “.oct” type using the built-in converter. To convert firmware from the original format to “.oct”, click “Firmware converter” (element 19). Working with phones based on MTK Microcontrollers http://www.freeimagehosting.net/uploads/884bfea75c.png Connecting the phone 1. Select “LG MTK” in the Octopus Box Software window (element 1). 2. Select phone model (element 2). 3. Select the COM port Octopus Box is connected to (element 3). 4. Select COM port baud rate (element 4). 5. Connect the phone to Octopus Box using a cable (to check the cable type, click “Cable: XXXX”) (element 5). Writing firmware to the phone 1. Connect the phone as explained above. 2.Select the firmware file compliant with your phone (element 6). 3. Click “Write Firmware” and follow program instructions (element 7). Reading Full Flash and EEPROM files 1.Connect the phone as explained above. 2.To read the Full Flash file, click “Read Full Flash” (element 8). 3. To read the EEPROM file, click “Read EEPROM” (element 9). Writing Full Flash and EEPROM files 1. Connect the phone as explained above. 2. To write the Full Flash file, click “Write Full Flash” (element 10). 3. To write the EEPROM file, click “Write EEPROM” (element 11). Formatting File System 1.Connect the phone as explained above. 2.Click “Format FFS” and follow program instructions (element 12). Reading unlock codes 1. Connect the phone as explained above. 2. Click “Read codes” and follow program instructions (element 13). Unlocking the phone 1. Connect the phone as explained above. 2. Click “Unlock” and follow program instructions (element 14). Repairing phone reset 1. Connect the phone as explained above. 2. To repair phone reset after overloading it with content, click “Repair phone reset” and follow program instructions (element 15). Reading the phone information 1.Make sure the phone is on and connect it to Octopus Box as explained above. 2.Click “Read phone info” (element 16). Fixing the IMEI serial number 1.Make sure the phone is on and connect it to Octopus Box as explained above. 2. Enter the original 14 digit IMEI serial number in the corresponding field (element 17). 3. Click “IMEI Fix” (element 18). Converting firmware 1. Octopus Box Software uses its own type of files (.oct). You can use files from the Support zone or convert native LG flash files to the “.oct” type using the built-in converter. To convert firmware from the original format to “.oct”, click “Firmware converter” (element 19). Working with phones based on SEMC Microcontrollers http://www.freeimagehosting.net/uploads/f647a56485.png Connecting the phone 1. Select “LG SEMC” in the Octopus Box Software window (element 1). 2. Select phone model (element 2). 3. Select the COM port Octopus Box is connected to (element 3). 4. Select COM port baud rate (element 4). 5. Connect the phone to Octopus Box using a cable (to check the cable type, click “Cable: ХХХХ”) (element 5). Writing firmware to the phone 1. Connect the phone as explained above. 2. Select the firmware file compliant with your phone (element 6). 3. Click “Write Firmware” and follow program instructions (element 7). Reading Full Flash and GDFS files 1. Connect the phone as explained above. 2. To read the Full Flash file, click “Read Full Flash” and follow program instructions (element 8). 3. To read the GDFS file, click “Read GDFS” and follow program instructions (element 9). Writing Full Flash and GDFS files 1. Connect the phone as explained above. 2. To write the Full Flash file, click “Write Full Flash” and follow program instructions (element 10). 3. To write the GDFS file, click “Write GDFS” and follow program instructions (element 11). Unlocking the phone 1. Connect the phone as explained above. 2. Click “Unlock” and follow program instructions (element 12). Repairing the phone 1. If the phone won’t connect due to a wrong firmware, use the “Repair” button (element 13). Using the testpoint 1. To restore the phone, select “Use testpoint” (element 14). 2. To connect the phone using testpoint, you need to connect jumper according to the picture. To see the picture, click “Show testpoint” (element 15). Converting firmware 1.Octopus Box Software uses its own type of files (.oct). You can use files from the Support zone or convert native LG flash files to the “.oct” type using the built-in converter. To convert firmware from the original format to “.oct”, click “Firmware converter” (element 16). |
where can we buy this box is there a reseller here in the Philippines? how much is the cost? |
You can buy Octopus Box from any country in the world. The list of official resellers is here: http://octopusbox.com/buynow |
NOT ABLE TO FIND ANY RESELLER IN INDIA. WBR sahil2000ind |
can this tool unlock and/repair Lg U400? |
Need a resaller in Pakistan.Let us know any resllaer located here. br |
any reseller for philippines? |
Hope this will not ask for Money after 6 Month ? |
yes its same as smart clip , after one year i think it will ask for money for downloading files from support !! correct me if i am wrong BR Faisal_Computer |
boot loader ............................... ............................... I agree with u any way price in dollers..? |
hi there new user here http://i148.photobucket.com/albums/s...81/octopus.jpg i dont know whats the problem here http://i148.photobucket.com/albums/s...topuserror.jpg pls help i dont know where can i get files for supported model thanks shoktong |
Type https://www.boot-loader.com Should solve certificates mismatch. Or just add an exception to your browser. |
all ready register there but it say invalid user/password pls try again if i register new it said some one using my email what this problem sir? pls check br shoktong |
2 shoktong: PM me please your boot-loader's username and e-mail address. Seems you do not activate your account yet. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com https://www.boot-loader.com http://www.gsmserver.com/img/sc_userbar_1.png http://www.smart-clip.com/img/fb.png Become a Boot-Loader v2.0 Fan |
