04-09-2015, 05:11 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: near da border
Member: 861495 Status: Offline Thanks Meter: 52 | octopus help MS500 nvm and qcn |
04-09-2015, 06:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please install latest Software version (Software), fully charge phone's battery by using external charger and repeat the "Unlock" operation with enabled (marked) "Skip Read/Write QCN during the Unlock operation" option in the Software. Then insert SIM card, wait 5-7 minutes and try to find and select network manually. Post here the result. |
04-09-2015, 07:18 | #5 (permalink) |
Member: 861495 Status: Offline Thanks Meter: 52 | Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: MS500 Reading info...OK Mode: Normal Model ID: LGMS500Z: ÿd Firmware compiled date: Mar 24 2014 Firmware compiled time: 20:58:37 Firmware released date: Mar 24 2014 Firmware released time: 20:58:37 SW Version: LGMS500Z00 IMEI: 014143-00-191783-2 SPC: 000000 Unlocking... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Enable "Settings" -> "Developer options" -> "USB debugging" option 4. Connect cable and check if ADB interface has appeared in PC Device Manager. tried unlocking in download mode wont work |
04-09-2015, 07:24 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Disconnect all other devices from PC, re-boot the PC, fully charge phone's battery by using external charger, turn on USB Debugging Mode and try again. Post here the result. Also post log with the "Unlock" operation from Download Mode. |
04-09-2015, 08:15 | #7 (permalink) |
Member: 861495 Status: Offline Thanks Meter: 52 | Checking data...OK Platform: LG Qualcomm Selected port: COM24 Selected model: MS500Z Reading info...OK Mode: Emergency Model ID: BS/LGMS500/205030 SW version: LGMS500AT-02-V12b-310-260-MAR-24-2014+0 Product ID: CT62S140904001010 IMEI: 014143-00-191783-2 Unlocking... Switching to Normal mode... Found model LGMS500Z: ÿd at port COM24 Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Enable "Settings" -> "Developer options" -> "USB debugging" option 4. Connect cable and check if ADB interface has appeared in PC Device Manager. still locked |
04-09-2015, 08:19 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We have prepared and sent You test Software version to PM. Install this Software, disconnect all other devices from PC, re-boot the PC, fully charge phone's battery by using external charger, turn on USB Debugging Mode and try to perfrom the "Unlock" operation fom Normal Mode. Post here the result. Try to perfrom the "Unlock" operation on another PC. Also, look here: http://forum.gsmhosting.com/vbb/10975484-post3097.html. |
04-09-2015, 18:58 | #9 (permalink) |
Member: 861495 Status: Offline Thanks Meter: 52 | unfortunetly this the only fone ive had trouble with ,customer wanted fone back paid code and got it done but we still need a good qcn file on support it wasnt getting 4g but customer didnt mind |
