12-31-2014, 17:28 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: TURKEY
Member: 1245396 Status: Offline Sonork: BR*BY*PROF*47*47* Thanks Meter: 109 | octopus team ls995 imei repair error Internal error! Error code: Z1AL3CAS2Q [Solved] Platform: LG Qualcomm Selected port: COM24 Selected model: LS995 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LG-LS995 SW version: LS995ZV3_17 LAF Version: 1.0 Product ID: PT04S140114003892 IMEI: 352396-0-6 Target operator: SPR Hardware: rev_10 Battery level: 62% Fixing IMEI... New IMEI: 332199-34-5-5 Internal error! Error code: Z1AL3CAS2Q Last edited by Octopus box; 01-13-2015 at 08:06. |
12-31-2014, 17:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please do the next: 1. Install latest version of the Software. 2. Install "LG United Mobile Driver v 3.8.1". 3. Install "LG Android ADB Driver". 4. Remove SD and SIM cards from the phone. 5. Connect powered-on phone to PC with Micro USB cable. 6. Enter correct IMEI. 7. Click "IMEI fix" button. Note 1: Phone should be connected directly to PC. Try to use different USB ports for connection. Note 2: To connect the phone in Normal Mode, do the next: Type ##3424#, go to "Diag" menu and select "Enable". This menu is blocked by SPC/MSL, which can be provided by network provider. |
12-31-2014, 19:05 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
Also look here: http://forum.gsmhosting.com/vbb/10713547-post2903.html. | |
01-12-2015, 19:11 | #6 (permalink) |
Member: 1245396 Status: Offline Sonork: BR*BY*PROF*47*47* Thanks Meter: 109 | report imei repair work thanks mr octopus box log Checking data...OK Platform: LG Qualcomm Selected port: COM167 Selected model: LS995 Reading info...OK Mode: Normal Model ID: LS995ZV3:˙h° Firmware compiled date: Dec 04 2013 Firmware compiled time: 19:00:00 Firmware released date: Dec 10 2013 Firmware released time: 01:16:06 SW Version: M8974A-AAAANAZM-2.0.20018 IMEI: xxxxxxxxxxxx805-5 SPC: 100915 MEID: 99xxxx356012661 Mobile ESN: 80936678 SSD_A: A91C6FAF0049DF1B SSD_B: 646A1E5065803B65 AKEY: 14219031156078507282 OTKSL: 160600 NAM Name: Sprint MDN: 859-552-9051 User Lock Code: 8193 SID/NID: 4139 / 65535 MCC: 310 MNC: 00 MIN1: 2859903 MIN2: 606 Fixing IMEI... New IMEI: xxxxxxxxxxx4805-5 IMEI successfully fixed! Please, reboot the phone manually. |
