Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 33
Member: 14279 Status: Offline Thanks: 20
| P500 stuck in emergency mode. coustumer triet to upgrade phone's firmware and ended in emergency mode. cannot flash firmware with octopus, with or without write bootloaders option checked. i've tried both 10v and 20v firmware without succes. any help would be appreciated. Welcome to Octopus Box LG Software version 2.1.3 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM14 Selected model: P500 Reading info...OK Mode: Emergency Model ID: BS/P500/7D Opening "LGP500-FOR-UNLOCK.oct"...OK Checking partition...OK Write BootLoaders: Yes Writing QCSBL header...OK Writing QCSBL...OK Writing OEMSBL... Failed! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM14 Selected model: P500 Reading info...OK Mode: Emergency Model ID: BS/P500/7D Opening "LGP500-FOR-UNLOCK.oct"...OK Checking partition...OK Write BootLoaders: No Writing AMSS...Failed! -------------------------------------------------------------------------------- |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks: 3,683
| Hello. Please perform the next steps: 1. Put the phone into Emergency Mode manually (disconnect the cable, reconnect the battery, press and hold "Back" + "Vol+" + "Power ON" keys and connect the USB cable). 2. Make Unlock. 3. Put the phone into Emergency Mode manually again. 4. Select firmware "LGP500AT-00-V20c-EUR-XX-JUN-20-2011+0". 5. Select (check) "Write boot loaders" option. 7. Press "Write firmware" button. Note: if there will occurs an error during process of writing firmware, You mandatory should reconnect the battery and put the phone into Emergency Mode manually and repeat the procedure of writing firmware again! Otherwise, phone's boot can be damage! Please uninstall all BB software, modem dashboard software and PC Suite software. Also please don't use USB hubs or PCI USB ports, You need to use motherboard USB ports only! Also please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. |
| | #3 (permalink) |
| already done that. 6/22/2012 1:22:14 PM > Platform: LG Qualcomm 6/22/2012 1:22:14 PM > Selected port: COM14 6/22/2012 1:22:14 PM > Selected model: P500h 6/22/2012 1:22:14 PM > Reading info...6/22/2012 1:22:14 PM > OK 6/22/2012 1:22:14 PM > Mode: Emergency 6/22/2012 1:22:14 PM > Model ID: BS/P500/7D 6/22/2012 1:22:14 PM > Opening "LGP500AT-00-V20c-EUR-XX-JUN-20-2011+0.oct"...6/22/2012 1:22:14 PM > OK 6/22/2012 1:22:14 PM > Checking partition...6/22/2012 1:22:14 PM > OK 6/22/2012 1:22:15 PM > Write BootLoaders: Yes 6/22/2012 1:22:15 PM > Writing QCSBL header...6/22/2012 1:22:15 PM > OK 6/22/2012 1:22:15 PM > Writing QCSBL...6/22/2012 1:22:15 PM > OK 6/22/2012 1:22:15 PM > Writing OEMSBL... 6/22/2012 1:22:16 PM > Failed! also tried with this flash as i've seen you;ve recomended on another thread: 6/23/2012 1:31:05 PM > Platform: LG Qualcomm 6/23/2012 1:31:05 PM > Selected port: COM14 6/23/2012 1:31:05 PM > Selected model: P500 6/23/2012 1:31:05 PM > Reading info...6/23/2012 1:31:05 PM > OK 6/23/2012 1:31:05 PM > Mode: Emergency 6/23/2012 1:31:05 PM > Model ID: BS/P500/7D 6/23/2012 1:31:05 PM > Opening "LGP509AT-00-V10l-TMO-US-OCT-23-2010+0.oct"...6/23/2012 1:31:05 PM > OK 6/23/2012 1:31:05 PM > Checking partition...6/23/2012 1:31:05 PM > OK 6/23/2012 1:31:05 PM > Write BootLoaders: Yes 6/23/2012 1:31:05 PM > Writing QCSBL header...6/23/2012 1:31:05 PM > OK 6/23/2012 1:31:05 PM > Writing QCSBL...6/23/2012 1:31:05 PM > OK 6/23/2012 1:31:05 PM > Writing OEMSBL... 6/23/2012 1:31:08 PM > Failed! 6/23/2012 1:31:27 PM > |
| | #4 (permalink) |
| as for unlock option i get this: 6/23/2012 1:38:21 PM > Platform: LG Qualcomm 6/23/2012 1:38:21 PM > Selected port: COM14 6/23/2012 1:38:21 PM > Selected model: P500 6/23/2012 1:38:21 PM > Reading info...6/23/2012 1:38:21 PM > OK 6/23/2012 1:38:21 PM > Mode: Emergency 6/23/2012 1:38:21 PM > Model ID: BS/P500/7D 6/23/2012 1:38:21 PM > Unlocking... 6/23/2012 1:38:21 PM > To avoid damaging your phone, please, follow these simple precautions: Use a clean PC (without any installed drivers and software for BlackBerry phones, modem Dashboard software, Phone PC suites software). Please, make sure the phone's battery is fully charged. You should not run any other programs or attach new devices to your computer during this operation! 6/23/2012 1:38:26 PM > Sending loader... 6/23/2012 1:38:26 PM > Failed! 6/23/2012 1:38:26 PM > Error code: ZXLCALSZXC 6/23/2012 1:38:47 PM > |
| | #5 (permalink) |
| Try to re-flash a few times, without Unlock. Uninstall all BB software, modem dashboard software and PC Suite software. Also please don't use USB hubs or PCI USB ports, You need to use motherboard USB ports only! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| blue Display in Nokia Cellphones | TheDon | Nokia Hardware & Hardware-Repair Area | 0 | 10-29-1999 18:28 |
| New menu item in 5110 | GeoMan | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 09-23-1999 20:24 |
| Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 07-31-1999 04:35 |
