07-08-2014, 06:34 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 152445 Status: Offline Thanks Meter: 16 | P659h not repair imei [Solved] Platform: LG Qualcomm Selected port: COM15 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Jan 7 2014 Firmware compiled time: 15:08:11 Firmware released date: Jan 7 2014 Firmware released time: 15:08:11 SW Version: P655H10b IMEI: 352134-06-004146-5 Fixing IMEI... New IMEI: 352183-06-004146-2 Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Reading NVM...Failed! Backup saved to "P655H_352134060041465_08-07-2014_00-24-50.NVM" this with flash support and nothing the model is p659h, p655h detects as Last edited by Octopus box; 02-17-2015 at 07:09. |
07-08-2014, 06:45 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As I see, your device is detected by Software as P655H, not as P659H: Quote:
1. Install the latest Software version (Software). 2. Fully charge phones battery by using external charger. 3. Connect the phone directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. 4. Select P655H in the Software list. 5. Perform the Repair IMEI operation again. 6. Post here full Software log. Try to repeat the operation on another PC. | |
07-23-2014, 19:50 | #3 (permalink) |
Freak Poster Join Date: Jun 2011 Location: colombia
Member: 1603212 Status: Offline Thanks Meter: 26 | hello team optupos this error happens with help ------------------------------------------------------------ Platform: LG Qualcomm Selected port: COM71 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Mar 10 2014 Firmware compiled time: 11:32:34 Firmware released date: Mar 10 2014 Firmware released time: 11:32:34 SW Version: P655H10b IMEI: 3526xxxxxxxxxxxx Fixing IMEI... New IMEI: 354566-87-887780-4 Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Reading NVM...OK Backup saved to "P655H_3526xxxxxxxxx_23-07-2014_20-37-39.NVM" Reading partition...Failed! |
07-23-2014, 20:00 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We will research this problem and will try to prepare test Software version for You. |
07-24-2014, 06:37 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We have sent You test Software version to your PM. Please fully charge phones battery by using external charger and try to repeat the operation by using this Software. Write here the result. |
07-25-2014, 17:08 | #6 (permalink) |
Member: 1603212 Status: Offline Thanks Meter: 26 | optupos team tried several times to help Platform: LG Qualcomm Selected port: COM191 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Mar 10 2014 Firmware compiled time: 11:32:34 Firmware released date: Mar 10 2014 Firmware released time: 11:32:34 SW Version: P655H10b IMEI: 352634-06-004780-0 Fixing IMEI... New IMEI: 35263xxxxxxxxx Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Reading NVM...OK Backup saved to "P655H_35268xxxxxxxxx_25-07-2014_17-57-45.NVM" Reading partition...Failed! |
07-28-2014, 19:06 | #8 (permalink) |
Member: 1603212 Status: Offline Thanks Meter: 26 | Platform: LG Qualcomm Selected port: COM71 Selected model: P655H Reading info...OK Mode: Normal Model ID: P655H10b: ÿd Firmware compiled date: Mar 10 2014 Firmware compiled time: 11:32:34 Firmware released date: Mar 10 2014 Firmware released time: 11:32:34 SW Version: P655H10b IMEI: 352634-06-004780-0 Fixing IMEI... New IMEI: 352634-08-787780-9 Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is already rooted. Reading NVM...OK Backup saved to "P655H_352634060047800_28-07-2014_19-58-48.NVM" Reading partition...Failed! |
08-13-2014, 10:09 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Firmware for LG P659H is available in Support Area (press "Go to support" button in Software to access Support Area). |
08-13-2014, 21:05 | #12 (permalink) |
Member: 1603212 Status: Offline Thanks Meter: 26 | Platform: LG Qualcomm Selected port: COM71 Selected model: P655H Reading info...OK Mode: Emergency Model ID: BS/LGP659H/112510 SW version: LGP659hAT-00-V10a-TGO-XXX-JAN-23-2014+2 Product ID: CD28S140319002480 IMEI: 013657-00-054250-8 Opening "LGP659hAT-00-V10a-SSV-JAN-07-2014+0.oct"...OK Initializing flash...OK Reading partition...OK Formating userdata...OK Hi octopus team I have several days with this team failed to repair imei software for imei repair failed defenitiba solution |
08-14-2014, 16:09 | #13 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
08-14-2014, 16:53 | #14 (permalink) |
Member: 1603212 Status: Offline Thanks Meter: 26 | hi i tried writing firmware here but here goes from my proble is that this phone will not let ecribir firware not change imei and I have no flas and happens from here |
08-15-2014, 08:28 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please contact us to Skype, Yahoo! Messenger, or ICQ - we will check remotely where can be the problem with Your phone. Our contacts You can find in our profile. |
