06-25-2014, 10:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | P712 Problem help please I have a problem with P712 I try to make a hard reset and I cant I flashed but the phone not restored When I enter in the menu-restore cant delete user data, nothing happend Also I make Factory Reset with sw and nothing happend Can help me please ? Thanks |
06-25-2014, 10:19 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to do the next: 1. Fully charge phone's battery. 2. Install the latest Software version (Software). 3. Re-connect the battery and put the phone into Emergency/Download Mode manually. 4. Make Repair security. 5. Re-connect the battery and put the phone into Emergency/Download Mode manually. 6. Re-flash the phone. 7. Power the phone on and make Repair NVM. 8. Write here the result. |
10-17-2014, 10:23 | #5 (permalink) |
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | This is the log -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM59 Selected model: P712 Reading info...OK Mode: Normal Model ID: LGP712 Firmware compiled date: Feb 22 2013 Firmware compiled time: 00:00:00 Firmware released date: Jan 20 2014 Firmware released time: 16:59:21 SW Version: LGP712AT-00-V10a-SCA-XXX-MAR-01-2013+0 IMEI: 355737-05-377xxxx-x Switching to Download mode...OK Searching security area...OK Reading security area...OK Backup saved to "P712_3557370537xxxxx_17-10-2014_06-20-50.SEC" Analyzing security... Writing security area...OK Switching to Normal mode... Found model LGP712 at port COM59 Finalizing...OK Rebooting phone...OK Security succesfully repaired. Rebooting phone... |
10-17-2014, 10:49 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Re-flash the phone again. If the problem is the same - check phone's HW, most likely, this is HW issue. |
